Go to Post As a team sponsor, we are more concerned with the behavior, attitude and commitment to FIRST ideals than specific performance in the competition. Some of our teams perform well, some struggle, some are in the middle. We support them all in every way we can. - Chris Fultz [more]
Thread Tools Rating: Thread Rating: 3 votes, 4.67 average. Display Modes
  #39   Spotlight this post!
Unread 21-11-2003, 15:40
Mr. Ivey's Avatar
Mr. Ivey Mr. Ivey is offline
Mark Ivey
AKA: Mark
Mr. Ivey is a glorious beacon of lightMr. Ivey is a glorious beacon of lightMr. Ivey is a glorious beacon of lightMr. Ivey is a glorious beacon of lightMr. Ivey is a glorious beacon of light
Send a message via AIM to Mr. Ivey
Yeah, I'm glad I found this tread, it has a lot of good information, but I have worked on a design and have finished it today! But there are a few problems, I haven't been able to decide a way to make the planet gears to stop when I need them to, but I have a pretty good idea of how it should work, and it also relies a good amount on making the ring gear rotate by friction, because at some points you must let the planets rotate freely and such. The biggest problem is that one motor must overcome the resistance put forth from it's opposing sun gear, this could cause problems in the electrical system. But the two sun gears are where the power comes from, and then transfered to the planet gears, and then to the ring gear. The ring gear is the gear that will be attached to the rest of the drive system. I'll post the link as so as I get it uploaded.
Ivey
When you tell a student not to do it, you shouldn't do it. Or else you will wind up with a 3/8" drill bit in your finger... Like I did...
