My love spiders out in a web of emotions when I think of you.
Unread 05-12-2003, 02:37
Matt Adams's Avatar
Matt Adams Matt Adams is offline
b(o_o)d
FRC #1525 (Warbots)
Matt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond repute
Send a message via AIM to Matt Adams
Post Re: Shifting Gears
Originally Posted by MBosompra
Please offer any and all words of advice it's greatly appreciated. We are rookies at building gear boxes. We're not sure which equations to use or even were to start. Please help.
Alrighty, it appears that you're in sort of a bind (bad pun intended) with where to start, so I'll sort of give you some (or a lot) of background on transmissions. Please don’t take my words as absolute truths, but instead use them balanced with some other veterans to come to your own conclussions. Some people more talented than myself may disagree with some of what I have to say.
Thoughts on Transmissions in FIRST.
When choosing a transmission design, you have to weigh a few different aspects before making your choice: The most important aspect is your justified purpose of having the transmission in the first place. Robots can maneuver reasonably well without the potential headache, cost, and design time needed to create a transmission.
The foremost purpose of any transmission is to effectively provide an adequate balance of speed and torque for a given situation. Typically in FIRST, a transmission implies more than one torque and speed setting which is adjustable during a round.
In FIRST robotics, your drive train must be able to do two things effectively:
1. Move from one point to another as quickly as possible, typically in a specific orientation.
2. Maneuver in "high torque situations" against field playing objects and opposing robots.
Without going into the details of the analyses that I’ve performed, the amount of torque required in "high torque situations" is approximately 2.5 to 3 times as much torque as required for standard and high speed maneuvering situations. Essentially, pushing a robot requires significantly more torque than is required for simple turning, which requires more torque than just moving forward and back.
Some quick facts on transmissions are written below. When I spit out numbers, these are calculated. Please ask questions about any and all of it if you’d like more information.
1. The proper gear ratio for using the drill motor in low speed, with 6 inch wheels, a 130 lbs robot with a coefficient of friction of 1.2, while not pulling more that 37 Amps is about 2.5 to 1. Using any less than this ratio with those assumptions will lead your robot to trip the 40 Amp circuit breaker while in pushing matches, no questions asked.
2. The limiting factor in almost all drive trains using a single pair of motors is tripping the circuit breakers of the individual motors. The circuit breakers for the chips and drill motors are 40 amps, while the stall current, (the amount of current that a motor is using while it is exerting is maximum (stall) torque), is over twice that of the breaker. Thus, even if the wheels are spinning due to slip, you can still be pulling more current than is permitted by the breakers.
3. If you choose to couple a drill motor and an Atwood motor in single side of a drive train design, (using 4 motors total) your danger lies in pulling more than 120 Amps which would trip the master circuit breaker.
4. Transmissions are (relatively) engineering and manufacturing intensive, as gears have much tighter tolerances than most other features of a robot, such as some sort of macro level manipulator. They are also much more detrimental when the fail, since when your drive train is not working, neither is your robot. Hence, special care and adequate resources must be applied such that a transmission performs effectively. Failure of your drive train and transmission can completely ruin an entire competition or potentially an entire season.
5. Transmissions, obviously, have a weight associated with them. Typical transmissions have weights between 3 and 8 lbs. per side. Often, this is primarily determined by the quantity of steel required in the gearing and meshing components. Using more than a single pair of motors can further increase weight by 8 to 10 lbs., depending on mounting and gearing required.
6. Transmissions have relatively high financial costs. Since each gear average ~$25, and you’ll be requiring between 6 and 10 gears per side, the total cost adds up quickly. Often times, for fiscially conservative teams, this means that having replacement gears may not be an option.
With those facts put out there in the open, I’ll talk about my personal thoughts on transmissions. Again, please comment as you agree or disagree.
It should be noted that there is a finite (limited) amount of force that a robot can push on the field. In a four-wheel drive system, this is equal to the weight of the robot times the coefficient of friction (stickiness of the wheels to the ground). Even if you have a max output torque by your motors equal to that of a V8 automotive engine, you won’t be able to push more than the weight of the robot times that coefficient of friction. (which is typically in ideal situations, about 1.1 to 1.5)
With all of this being said, I have calculated that you can move at a relatively high speed, ~10-12 feet per second, as well as push other robots with the use of only a single pair of motors, and a pair of properly chosen gear ratios.
To further extrapolate on this, I believe that it is (though admittedly very debatable) wasteful to use a second pair of motors. Below is my justification.
As I stated, a drive train with a single motor pair using proper gear ratios can reach the maximum amount of torque required, which means that a second pair of motors will only provide a different (higher) maximum speed. With that said, I would like to state the primary disadvantages of using a second motor pair.
1. The additional actual weight of a motor pair, the gearing needed to mesh with the first set of motors, as well as the required mounting of these motors could add between 8 and 15 lbs to your robot.
2. You run the risk of tripping your main (120 A) circuit breaker, which means that the entire robot will shut down for the rest of the round. Two motors could pull a maximum current no higher than 80 Amps, while 4 motors could pull 160 amps, dangerously above what will trip the main breaker.
3. At higher speeds, it is more difficult for the driver to accurately control the robot.
4. Twice the motor count means at least twice the complexity. Calculation requirements double, nearly twice the machining for motor mounts double, and at least twice as many pieces will require the high tolerances needed for an efficient drive train.
Hence, it is in my opinion that with the current rules that are in place with FIRST robotics, a second motor pair is a waste of resources, since the primary purposes of a transmission can be achieved with only one pair.
However, YOU need to decide: is it worthwhile to spend twice (or more) the machining, twice (or more) the cost, twice (or more) the design time, and twice (or more) the weight simply so that your robot can move FASTER. You need to decide what is fast enough.
Currently, Team 461 is working on a design that could potentially completely level the playing field for many financially strapped and machining limited teams by designing a transmission that:
1. Requires no machining beyond a drill press and bandsaw.
2. Has a total cost for a PAIR of transmissions less than $250
3. Has weight total less than 4.5 lbs per side.
More details are coming soon regarding that design.
Feel free to ask questions, make comments, or corrections.
Matt
Unread 05-12-2003, 10:23
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Re: Shifting Gears
Matt
I agree with 80-90% of what Matt has to say, but the above quoted comment is one that I feel I need to say something about.
In the 2002 season, many of the matches ended up being 120 second pushing matches. In addition, many teams lifted the goal(s) in order to get a higher normal force with the floor (resulting in more pushing force for the same coef. of friction). Finally, FIRST provided 80 Amp household breakers (read: "not rated for mechanical impacts") for the main power.
This combination resulted a number of teams with N motors per side (N>1) having issues with the breaker tripping, especially if they got bumped during or shortly after a pushing match.
Last year, FIRST switched to 120 Amp automotive aftermarket breakers. Between the higher current rating and the designer's expectation that cars see more shock and vibration than typical homes (West Coast teams excluded ;-), I don't know of any teams that had problems with the main breaker tripping last year, whether they had N motors per side or not.
This is not to say that there are not multiple reasons NOT to use N motors per side -- there are many, but tripping the 120 Amp breaker is not one of them (imho).
By the way, I have it from usually reliable sources that given the current breaker and the individual 40 or 30 or 20 amp circuit breakers, it is a very close call as to whether it is even possible to trip the breaker short of a metal bar shorting your main power feeds.
Depending on the state of the charge of your battery and the variation limits of your particular battery's internal resistance and the lengths of your wiring harnesses, it may be almost impossible to trip the main breaker.
Having said I agree with Matt, I will point out one reason for multiple motor drives that he ALMOST points out but does not quite complete the thought.
As Matt points out, in many cases, the 40 Amp breaker is the limited factor on the output of your drive system.
The consequence of this is that if you have 2 motors per side, you have 2X the 40 Amp current limit.
This was the case with our robot last year. In normal driving (i.e. practicing), our robot worked just fine. It had a good balance between top speed and turning/pushing torque. But after a while of "competition driving" the breakers would poop out on us at the whimpiest of pushing matches.
So... ...we retrofitted an extra set of motors per side for the sole purpose of pushing back the limits due to the single 40 Amp current path.
For what it is worth...
Joe J.
Unread 05-12-2003, 12:18
Matt Adams's Avatar
b(o_o)d
FRC #1525 (Warbots)
Re: Shifting Gears
I'll take an 80-90% from Joe any day.
<snip>
Joe J.
To comment on what Joe is saying, I understand his point. In addition, I have a few hunches as to why there were teams that used multiple motors and didn't trip the 120 Amp breakers:
Most of the time, teams who are using multiple pairs of motors have excellent designers in the first place, or copied the designs of excellent designers. In pushing matches, the teams were in their properly designed high torque gear set. This should have caused them little fear of tripping much of anything.
However, I would bet the farm that a robot in their high speed gear set pushing up against a wall would trip the 120 Amp breaker before any individual motors would give out.
So I'll definitely agree that Joe has a viewpoint that is very valid. My point was just a heads up: It theoretically possible to push that 120 Amp limit if your gear ratios are not designed properly. You must design your ratios with a limiting factor of the 120 Amp breaker if you use more than two motors.
If you assume that since you're using twice the number of motors, you can make your speed ratio twice as high, you'll be in trouble, since you don't have twice the power due to the 120 Amp circuit breaker. If the game changes this year to requiring some sort of manipulator that could be pulling another 10 or 20 amps... be alert!
To summarize, I'm giving a theory viewpoint for the new designer, while Joe is calling it like he's seen it (which is essentially that teams have designed multiple motor drive trains well! Woo hoo! ).
Thanks for the comments, Joe!
Unread 05-12-2003, 14:53
Matt Reiland's Avatar
'The' drive behind the drive
Re: Shifting Gears
Also don't totally forget about another reason for multiple motors -
Redundancy.
We used 2 per side last year and had the drills fail twice in the season, the previous year the fisher price failed 3 times. However the robot kept on moving since more than one motor was linked to the drivetrain (Although one side had less power we were not a sitting duck that drives in circles)
For our robot last year with Tank Treads, we were able to use a version of the 45 design that gave us the power we needed to push hard and spin the tracks against an immovable object and in high cover the field at a very quick pace. Both of these would have been somewhat less if we didn't have both the motors teamed together. We still would have had a high and low but they would have been slower. Also anyone considering building a transmission should be lightening out all of the gears to a geat extent to reduce the weight so that the total added is much less than 8-9 pounds per motor. We have shown that 20 pitch gears can be lightened nearly 80% and still hold up to the duty required of them in a 130 lb Drivetrain for an entire season.
So I guess I disagree that more than one motor per side is a total waste in a FIRST robot, it all depends on what you want your robot to do. Too fast for some people is not too fast for others. I have seen many people in complete control of RC Nitro cars at over 50 MPH and I have seen others that can't drive straight a 5MPH.
Robonaut Next Generation Control System Development
2003 GLR Champions (302,67,226)
2003 Buckeye Semi-Finalists(902,494,226)
2002 Nationals QuarterFinalists
2001 West MI QuarterFinalists
2000 GLR Semi-Finalists
Unread 05-12-2003, 15:43
AKA: Dr. Joe
FRC #0088 (TJ2)
Redundancy is a 2 edged sword...
One thing about redundancy: It can hurt you some times too.
On several occassions we have had one of our multiple motors fail or partially fail and not discover it for several matches.
The machine works, but it works at a lower level of performance.
This year, our team is planning on putting in a "diagnostic mode" in which every motor is tested while monitoring sensors (current, speed, etc.) for out of range values. We are also planning on having sensors similarly checked automatically.
I don't suppose that it will find 100% of the problems, but it could help us avoid a full speed crash into the wall during autonomous simply because of an unpluged cable (this really happened last year).
Joe J.
P.S. Breaker ratings have safety factors in them. Essentially, they can carry the rated current for infinite time. At some percentage above that rating, they trip after some time depending on the percentage of over current.
Bottom line, I estimate that a robot could probably dead short the battery for 5 or 10 seconds before it would actually trip the 120 Amp battery (don't try this at home as batteries do not like such dead shorts). Given our current battery, with the motors we have and the required secondary breakers, I think it would be hard to trip that main breaker.
Unread 05-12-2003, 17:11
Woodie Flowers Award
Ken Patton Ken Patton is offline
purple
FRC #0051 (Wings of Fire)
Ken Patton has a reputation beyond reputeKen Patton has a reputation beyond reputeKen Patton has a reputation beyond reputeKen Patton has a reputation beyond reputeKen Patton has a reputation beyond reputeKen Patton has a reputation beyond reputeKen Patton has a reputation beyond reputeKen Patton has a reputation beyond reputeKen Patton has a reputation beyond reputeKen Patton has a reputation beyond reputeKen Patton has a reputation beyond repute
two separate decisions
I think you made a great point Matt about each team needing to decide if they really need to add the complexity of a shifting system. It depends on the game, the field, and your strategy (none of which we know until after Jan 10th). You shouldn't add it unless you really need it. The simplicity and reliability gained by having a non-shifter is at the very least worth considering, especially for teams who are doing it for the first time.
Regarding whether or not there are benefits to multiple motors: there are. Adding the extra motor per side allows you to pick a numerically lower gear ratio that allows a higher top speed. Or if you choose to leave the ratio the same you will have more torque. Yes, it draws more current, but since a lot of the time you are in transient high current situations (i.e., just passing through a high current operating condition), you don't risk tripping the breakers. There are some teams that play it riskier than others, and those of us that have taken the risks can usually recall instances where we paid the price (ours was in 2002 where our 6-motor drive was in high gear and we tried to turn the goal 180 degrees - the main breaker tripped; this would not have happened in low gear).
2002 was the killer year. You needed speed (to get to the goals) and torque+traction (to move the goals). If ever there was a drivetrain-intensive year that was it. Multiple motors and shifting transmissions were very helpful.
I'd consider adding an extra motor before considering adding an extra gear ratio.
Ken
Unread 05-12-2003, 19:57
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Re: two separate decisions
Originally Posted by Ken Patton
Yes, it draws more current.
If Im not mistaken, while it draws more current, you are drawing less current per motor since the load is being shared between four motors rather than two. Since weve all basically agreed that the main breaker isnt going to trip, this would help keep individual motors from tripping their respective 40 amp breakers.
Cory
2001-2004: Team 100
2006-Present: Team 254
Unread 05-12-2003, 21:31
Tytus Gerrish's Avatar
Tytus Gerrish Tytus Gerrish is offline
IGAB, ADHD, and Dislexic
AKA: Ty
FRC #0179 (SwampThing)
Team Role: Tactician
Tytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond repute
Re: Shifting Gears
there was an idea floating around to blast the breakers with some liquid nitro or pack em with dry ice so they wouldnt trip. i dont know if anyone did it tho or even if they were allowed to
Unread 08-12-2003, 01:24
Matt Adams's Avatar
b(o_o)d
FRC #1525 (Warbots)
Thumbs down Re: Cooling Breakers
I know that in the past there have indeed been teams that have done this. While it's not forbidden in the rules, what you're really talking about is trying to get around a safety issue by modifying your breakers to a lower temperature so they don't trip. This is NOT a good idea. Tripping breakers shouldn't happen in the first place if everything is properly designed. The one exception may be during finals where you have back to back to back matches and breakers and motors heat up over extended use.
The most common way to cool your breakers is to take some of that keyboard cleaning compressed air. For long days of demonstrations, we've used compressed air to cool our motors down. However, this is honestly a pretty terrible engineering practice, and is NOT recommended.
Unread 08-12-2003, 08:32
Arefin Bari's Avatar
AKA: Ari
FRC #0108 (SigmaC@T)
Re: Shifting Gears
Originally Posted by Warren Boudreau
Shifting on the fly is a challenge.
we had a 2 shift transmission last year which could shift on fly...
low gear- 4 ft. per sec. 960 lbs of torque...
high gear- 10 ft. per sec. 416 lbs of torque...
Unread 08-12-2003, 10:35
kevin.li.rit's Avatar
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
Re: Shifting Gears
The biggest problem we had with our dual motor, dual speed gear boxes were stripping the 15t gears on the drill motor sides when going back and forth, it cost us a lot of matches in Annapolis.
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 08-12-2003, 10:49
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Re: Shifting Gears
in-lbs. or ft-lbs.?
--Madison--
...down at the Ozdust!
Unread 08-12-2003, 17:01
DanL DanL is offline
Crusty Mentor
FRC #0097
DanL is just really niceDanL is just really niceDanL is just really niceDanL is just really niceDanL is just really nice
Send a message via AIM to DanL
They actually make something called "freeze spray" - it comes in the same size and shaped bottle as the keyboard cleaning stuff, though. Yeah, you get the same effect, but since freeze spray is designed for cooling rather than blowing, you could probably get more for your money or cooler temps. It's also antistatic.
Can't give you any product brand or where my team got it... look around - I'm sure you'll find it.
Dan L
Team 97 Mentor
Software Engineer, Vecna Technologies
Unread 08-12-2003, 17:25
purple
Cory
You are right Cory, 2002 was the last time a lot of teams had problems with this. Although, I'm not sure that its simply a matter of us agreeing that it doesn't happen anymore. I remember an extremely fast machine (25) that appeared to have breaker problems in the finals at Houston last year. I don't know for sure if this was a main breaker problem or not.
Ken
Unread 08-12-2003, 17:47
Rob Colatutto's Avatar
Rob Colatutto Rob Colatutto is offline
Roboticsrob
FTC #10092 (Green.Griffins;)
Rob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to behold
Ken
That was them tripping thier main breaker. What team 25 had in 02 and in 03 was a servo actuated break that pushed into a whole drilled into one of thier drive gears that they used as a break since they were geared high both years so not much pushing power. The pin didn't come out all the way and thus when trying to moved they pulled a nice 220A or so and popped the breaker.
Matt, what method of shifting does that transmission that 461 is working on use? The only thing I could think of that does not require more than a lathe or mill would be a mesh shifter.
Follow me on twitter @roboticsrob and my FTC team @griffins10092
Regional & Division winners, did you shift gears or not? DougHogg Technical Discussion 34 02-05-2003 16:10
Helical gears that come with new drill motor Joe P Technical Discussion 4 12-01-2003 11:09
Best source for gears? Smallparts? drivetrain advice wanted! Frank(Aflak) Technical Discussion 11 10-01-2003 17:22
gears....? archiver 2000 16 23-06-2002 22:58
Need help! What kind of gears are we allowed to use?? Randy_Ai Technical Discussion 3 23-01-2002 22:56
