Go to Post note to self: do not use robot to retrieve cars from water. - Greg Marra [more]
Unread 20-12-2003, 14:02
Kevin Watson's Avatar
La Caņada High School
FRC #2429
EDU Demo Code: Encoder Interfacing Using Interrupts
I'm writing a motor controller that I intend to release in the future, but because of the interest in interfacing encoders lately, I've put together a small example that shows the best way I know to interface a quadrature encoder to the EDU robot controller. With this code, I've been able to track an encoder generating a few thousand counts per second. The code can be found here: http://kevin.org/frc.
-Kevin
Kevin Watson
http://kevin.org
