Go to Post All the powerhouse teams will be having powerhouses dinners with each other in the powerhouse restaurants, probably. - T^2 [more]
Unread 14-02-2002, 13:59
CJMJ CJMJ is offline
#0446 (Robodogs)
CJMJ is an unknown quantity at this point
PWM Pins and Housings
One of the engineers on our team calls them "C-Grid" connectors because they're at a .100 inch spacing. I ordered some [female] pins and housings from Digikey. If you go to their website, www.digikey.com, and search on 50-57-9003 (housing) and 16-02-0097 (female) pins you'll see what I ordered. I'm not 100% sure they'll work yet. They're due to arrive tomorrow. I'll post a follow-up message at that time. I'm also not sure yet if using these [or modifying the cables] are legal.
pwm 13-15 wayne 05 Programming 2 04-10-2003 12:08
PWM and burning out motors patrickrd Technical Discussion 7 19-06-2003 15:30
PWM Antonio Technical Discussion 21 06-01-2003 14:44
Loss of signal in PWM cables. archiver 2001 6 23-06-2002 23:29
PWM Wires... Anton Abaya Technical Discussion 3 04-02-2002 05:07
