Go to Post Life is unfair. Learn to deal with it or be unhappy. - Joe Johnson [more]
Unread 28-12-2003, 22:56
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Re: EDU Demo Code: Serial Data Transmitter Using a State-Machine
Originally Posted by KevinB
Thanks for posting this!
Our electrical team actually had the idea of using an LCD for feedback -- and this will make things easier on us!
Cool, I'm glad you can use it. Before you start looking at LCDs with serial interfaces, make sure that it supports TTL-level signaling and the baud rates that this software supports. For ease of use, I'd suggest looking at LCDs that support serial terminal-like interfaces too.
Of course, you're best bet is to find a LCD that can use the hardware serial ports built into the EDU controller (and presumably the full-size controller). If you want to use the dedicated TTL-level serial port, make sure that your LCD supports non-inverted TTL-level signaling.
Here is an great web page that discusses the different ways to communicate with a serial LCD: http://www.seetron.com/ser_an1.htm
-Kevin
Kevin Watson
http://kevin.org
Full list of teams & competitions archiver 2001 14 24-06-2002 00:52
Limiting PWM in pbasic archiver 2001 4 24-06-2002 00:38
