Go to Post As it stands your design defies physics (and breaks 1 of Karthik's 2 Golden Rules). - JesseK [more]
Unread 28-12-2003, 02:56
Wetzel's Avatar
Wetzel Wetzel is offline
DC Robotics
FRC #2914 (Tiger Pride)
Wetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond repute
Send a message via AIM to Wetzel
Re: Batteries
Originally Posted by KenWittlief
weight is not a primary concern for our bots ... If they gave us $200 batterys that were half the weight, you would hardly notice the difference in the performance (speed and handling) of our robots...
What competition are you competeing in? Have you never had to make swiss cheese?
An extra 6 lbs to play with would make a big diffrence in what we could do.
Wetzel
Unread 28-12-2003, 09:14
Re: Batteries
only if you failed to plan out your weight budget.
there is no reason FIRST could not increase the weight limit by 6 lbs if it were really a serious limitation
its not.
Unread 28-12-2003, 11:45
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
FRC #0148 (Robowranglers)
Re: Batteries
Then... within 2 years... someone would be calling out for 142lbs, because:
"An extra 6 lbs to play with, would make a big difference in what we could do!"
Then... within 2 years of that... 148lbs, because (you guessed it):
"An extra 6 lbs...."
This is why it's an engineering design challenge!
If you want it to be easy, go do battlebots .
Besides Jeff,
would you really WANT to give Wildstang 6 more lbs of aluminum?
I mean... jeez.
John
Unread 28-12-2003, 12:21
Jeff Waegelin's Avatar
El Jefe de 148
AKA: Midwest Refugee
Re: Batteries
Besides Jeff,
I mean... jeez.
John
Exactly... no matter how much FIRST would increase the weight limit (or lighten batteries, as the case may be here), people will still complain that they need more weight to work with, because they didn't budget their weight, or are trying to do something too large and complex. Being able to fit everything into the constraints is just part of the challenge of FIRST.
Jeff Waegelin
Unread 28-12-2003, 18:09
FotoPlasma FotoPlasma is offline
FotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond repute
Send a message via AIM to FotoPlasma
Re: Batteries
Originally Posted by sanddrag
As for the issue of starting a car, it is possible to do with a FIRST robot style battery. http://www.harborfreight.com/cpi/cta...emnumber=39954 I have one of these things and you can jumpstart a car at least 4 times before it doesn't have enough power to do it again. Also, what about those things you plug into the cigarette lighter to jump a car. How do they work and what batteries do they have?
As far as I know (and beware, I am no expert), the cigarette lighter circuit is connected, via the ignition system (as a switch), to the positive and negative leads on the car's battery. On most cars I've had the privelidge to replace a fuse in, the cigarette lighter circuit is fused at 10Amps, but I think most cigarette ligher male plugs have integral 3Amp fuses. As long as there's enough limiting resistance, the car needing the jump will be charged safely.
This is just what seems to me to be going on. I've never done it and, until now, haven't really been familiar with the practice. If I'm wrong, please correct me.
Unread 29-12-2003, 17:17
echos's Avatar
echos echos is offline
Jack of all trades
#1125
echos will become famous soon enough
Send a message via ICQ to echos Send a message via AIM to echos Send a message via MSN to echos Send a message via Yahoo to echos
Re: Batteries
I've been looking for a place in San Diego that sells TLP 4000C IntelliChargers like the one pictured below.
Unread 29-12-2003, 17:55
Adam Y.'s Avatar
Adam Y. Adam Y. is offline
Adam Y.
no team (?????)
Re: Batteries
Yeah but those guys use NiCad's and NiMh batteries in their robots. There really are disadvantages and advantages to all three of them. SLA's have high internal resistance which results in large and sudden voltage drop.
Spare Batteries Bob Steele Kit & Additional Hardware 7 14-02-2003 18:08
Where to purchase spare batteries? Patrick Wang Technical Discussion 5 17-01-2003 22:10
How often do you change batteries? archiver 2001 3 24-06-2002 00:22
HELP - We have no batteries!! Rick Gibbs Championship Event 3 24-04-2002 19:07
Help with batteries Keith Chester Kit & Additional Hardware 1 10-04-2002 12:08
