| Let's find ourselves a trailer and get hitched! |
#61
It Alive !
Metal in Motion version 2002 First came to life this past Monday.
Check it out on metalinmotion.com Don Taylor M-n-M |
#62
Well, we got our bot moving a couple of days ago... Clocked it at about 30 mph. Man does that thing move. Anyone want to drag race after the Canadian competition? j/k
Its not supposed to go that fast, but it is kinda cool. We found the gearing glitch, and it is running today with twice as many motors to boot. We have powerful motion. <breaker trips> TANJIT! Except for that. Ah vell... We will get that fixed. Azash 1/2 of the Programming Team for Swat Mobotics www.mowat.dhs.org "No matter who you are, you will always sound like a chipmunk when being fast-forwarded" |
#63
This has been answer by FIRST. If you read the Q&A from FIRST you will find out that you have to wieght your robot as it would be on the field. so if you do have different config. you need to wiegh them in at wiegh in. So you take off one thing and put something on as long as each config. is under 130lbs. we have 3 configs |
#65
we are.... we can go forwards, backwards, spin, go left, and go right
#66
we're a rookie team..but we got our robot hooked up to the gearboxes
it'll be moving tomorrow ![]() |
#67
Our robot, Coyobot III, also recently started running around. We're very happy that it is working so well right now. Good luck to everyone!
Check it out at http://www.crescentschool.org/robotics/ |
#68
We've done it !!
Its finally done...sorry no pics but here's to short of it... 4WD at the rear with a Chip/ Drill Motor combo (est. 400lbs Stall Torque) 8.5 Ft/S speed and some pretty cool goal grabbers See ya at the Hershey Center !! Team 873 SWAT MOBOTICS www.mowat.dhs.org |
| FYI: FIRST Robots at the NYC Hall of Science | Rich Wong | General Forum | 9 | 11-07-2002 10:52 |
| how effective do you think robots going under the bar | archiver | 2001 | 4 | 24-06-2002 00:36 |
| What about prettiest robots? | archiver | 2000 | 8 | 23-06-2002 23:09 |
| FIRST Meets BattlebotsIQ | K2unit | General Forum | 2 | 04-04-2002 11:37 |
| 'Accidently' ripping other robots apart | Vipersna | Rumor Mill | 6 | 04-01-2002 23:27 |
