Go to Post There is no MILSPEC standard for pool noodles. - Rick TYler [more]
Go Back   Chief Delphi > Technical > Robotics Education and Curriculum
Unread 05-01-2004, 15:53
Dave Scheck's Avatar
Dave Scheck Dave Scheck is offline
Dave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond repute
Re: Using an Operator Interface with the 2004 EDU RC wirelessly
Originally Posted by Neal Probert
Could we not just plug in the 2003 radio modem directly into the 2004 EDU/Full-Size RC?
We won't know until Saturday about the full-size controller, but as for the EDU...
The reasons that you can't plug the 2003 modem into a 2004 EDU are
1. It doesn't have a modem port.
You could create an external box that converted the serial signal of the modem to the inputs on the EDU. This would require a relatively simple microprocessor circuit.
2. You can't plug it into the serial port because the voltage levels are incompatible.
You could create an external box to shift the level of the modem signal, then plug into the serial port, and write some interface code to process the signal.
While both workarounds are good challenges, Dave's solution was designed to be a quick, low cost for teams that have a 2003 EDU, but do not have the resources to design the necessary interface circuitry.
I would imagine that at this stage in the game that most teams would be more interested in exploring how to write functioning C code than creating interface modules.
EDIT: Dave beat me to the punch in replying, sorry for the duplication
My hints and guess on the Game in 2004! Elgin Clock Rumor Mill 116 09-01-2004 13:30
2004 Championship Eligibility Criteria!!! dez250 General Forum 214 28-12-2003 20:11
2004 will be 2 v 2 Gadget470 Rumor Mill 20 25-10-2003 21:32
2004 Goals Rich Kressly FIRST Interactive Rural SupporT 2 19-10-2003 18:09
2004 OCCRA Competition Gadget470 OCCRA 2 11-06-2003 12:37
