It is legal to hook them up in parallel - which means that you can run separate wires from the battery to each panel.
Do not, however, wire two fuses in parallel! You could damage whatever you are trying to protect with the fuse, or even start a fire. Aside from that, it's against the rules. |
| Where to Buy 40-Amp Fuse Panels? | yangotang | Electrical | 9 | 11-11-2003 18:44 |
| picture of 40 amps fuse holder and fuse | rcubes85 | Technical Discussion | 1 | 13-02-2003 16:03 |
| Blowing 60 Amp fuse | archiver | 1999 | 4 | 23-06-2002 22:07 |
| What teams have cool control panels? | Ragin_Kage | Robot Showcase | 1 | 09-05-2002 17:43 |
| how do u hook up things through the fuse panel? | chrisw | Technical Discussion | 9 | 12-01-2002 19:51 |
