Go to Post to all of the people who are on robotics, I thank you for giving me the chance and happiness that i had never had before. robotics has been the happiest thing i have ever done in my life - gondorf [more]
Unread 13-01-2004, 12:56
Fred Hord Fred Hord is offline
Fred Hord is on a distinguished road
Re: PSI formula for pneumatic pistons
Originally Posted by Ryan
What is the formula to figure out the PSI a pneumatics piston can hold?
The maximum working pressure you can use is 60 psi. In order to determine the force of the cylinder multiply the pressure you are using times the area of the piston. See the pneumatics manual for a chart on this.
Inverse Tangent D.Viddy Programming 10 25-01-2003 22:24
Auto Air Pump Code zorro Programming 25 05-01-2003 16:50
