Go to Post Build season is the best time of the year. Better than Christmas because the presents are cooler, and better than new years cause you get to stay up later. - burkey_turkey [more]
Unread 23-01-2004, 09:37
Matthew_H's Avatar
Matthew_H Matthew_H is offline
Ubergeek
#1028 (Ubergeeks)
Matthew_H will become famous soon enough
Send a message via AIM to Matthew_H Send a message via MSN to Matthew_H
Re: White Paper Discuss: 2 speed, Shift-on-the-fly TechnoKat Gearbox
Originally Posted by Joe
I was wondering if you could share any kind of CAD format of this file, because we have metric units here in Brazil, and we´ve to see all details of the gears because we don´t have them available to buy here.
Thanks.
I had one of my drafting students put this desgin into CAD. It should show you the basics of the design. I have not fully checked it out but if you would like it send me an email and I will attach it.
Matthew
Ubergeeks
Unread 23-01-2004, 14:15
Guilherme's Avatar
Guilherme Guilherme is offline
Guilherme Balbinot
AKA: Guilherme Balbinot
Guilherme will become famous soon enough
Send a message via MSN to Guilherme
Thank you all. Andy already sent me the .step file, it should be enough.
Three more questions:
Andy, I was at our high school, but now I´m at home and I don´t have your email adress. May you send me the Unigraphics files? We´re trying to get a sponsorship from a company that has CNC´s, so we could build the parts with these files.
I´ve spoken to this company, and they said that in order to build gears, the should have special tools engaged in their CNC´s. Could ou specify the tools needed to build ALL gears? The models of their CNC´s are: feeler model FV 1100, dyna Myte model 4500
Whats the average time that this gearbox takes to be built?
Guilherme Balbinot
Unread 23-01-2004, 15:30
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
When we were asking around at local machine shops, they said it would be around 40 hours of work. That does seem possible, albeit a bit steep. It really depends what's being CNC'ed and what needs to be done manually.
Cory
2001-2004: Team 100
2006-Present: Team 254
Unread 23-01-2004, 20:16
Matt Reiland's Avatar
'The' drive behind the drive
40 Hours seems possible, however do yourself a favor and make extra parts. Lots of the machining time is the setup, once the CNC portion is programmed, making an extra few is much easier and you may need it later.
Robonaut Next Generation Control System Development
2003 GLR Champions (302,67,226)
2003 Buckeye Semi-Finalists(902,494,226)
2002 Nationals QuarterFinalists
2001 West MI QuarterFinalists
2000 GLR Semi-Finalists
White Paper Discuss: Dual Motor Gearbox - 2003 CD47-Bot Extra Discussion 6 08-04-2004 19:46
Some code in C that we may need if we are in trouble Andrew Rudolph Chit-Chat 16 07-10-2003 21:34
Shift on the fly LEGO gearbox rlowerr_1 Robot Showcase 17 14-07-2003 23:33
