Go to Post Having a spare arm that you can put on in 5 minutes or less intimidates the hardware into not breaking. - ChrisH [more]
Unread 20-02-2002, 16:05
Ulibrium Ulibrium is offline
#0920 (Lancers)
Ulibrium is an unknown quantity at this point
Send a message via AIM to Ulibrium
Ok, here are the details. All I know is what they told me when they tested the robot, because unfortunately our team worked on the 'bot up until the last day and we had zero time to debug. Additionally, I wasn't there when they got it running so they had to figure things out without me. We designed a control system which includes a custom VB dashboard plugged into the serial dashboard port of the OI, and a steering wheel. We programmed the RC for steering wheel support on the USER slot and 2-joystick support on the DEFAULT slot. This way, if the calibration is funky, we can just fall back on a surefire system. The only difference between the two programs is a scaling factor, because steering wheel output only seems to range between 183-254, for example, instead of the full 0-254, and also a forward/reverse flag that is triggered by one of the buttons on the steering wheel. At the time of robot operation, nothing was plugged into program port of the RC. They reported to me that the BASIC Run Error LED would come on much more often for steering wheel drive than for joystick drive. This puzzles me. As soon as I get back in, I'm going to scour the code for debug statements and purge it. If this is the problem, I'll return and make you guys aware. Otherwise, I need some help.
P.S. They would have been aware if the battery voltage drops. That is part of our dashboard.
Three mathematicians slave over a board full of tensor calculus. One looks to the other and asks... "do you remember what we sent out to prove?"
Impending BASIC Stamp Editor Beta 2 release Greg Ross Programming 9 19-09-2003 06:05
Basic Run Error BBFIRSTCHICK Programming 10 02-04-2003 22:43
Basic Init Error yan184 Programming 5 14-12-2002 13:10
BASIC error punarhero Programming 4 16-02-2002 23:21
BASIC Stamp Error mpatterson Programming 4 22-01-2002 12:08
