Go to Post Earlier this week it took me a little bit too long to realize that the reason my pen wasn't writing correctly was that it was actually a screwdriver. I'm going to have to ask for a few nights of honest sleep before signing off on a report. - EricVanWyk [more]
Unread 22-01-2004, 20:16
tml240's Avatar
tml240 tml240 is offline
bahh
tml240 is on a distinguished road
default code and the actual robot
ok did anyone have problem with the default code not working with the 'default wiring'? cuz ours seems to have a problem and we're trying to fix it
OHL 2004- ultimate NHL 2004 MOD
Unread 22-01-2004, 20:41
tml240's Avatar
bahh
Re: default code and the actual robot
*bump...
Unread 22-01-2004, 20:53
hello world's Avatar
hello world hello world is offline
hello world has a little shameless behaviour in the past
Exclamation Re: default code and the actual robot
hey BK
please do try to edit your messages before you post them. this applies to theory 6 forums as well
Unread 22-01-2004, 22:10
tml240's Avatar
bahh
im not good at grammar
Unread 22-01-2004, 22:13
Stephen Kowski's Avatar
BSEE, MSEE, JD
AKA: employed
what is wrong specifically? i know we had to reupload the default code like the default code reference guide suggested....mainly our prob was with the compressor and that fixed it...
Unread 22-01-2004, 23:35
tml240's Avatar
bahh
my question was that when u just built the default code and loaded it onto the robot, does it work (robot's movement) properly for you guys?
Unread 23-01-2004, 13:46
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
It worked as expected for us. We ploped it in last year's bot (Not Dig.IOs or Analog) and it worked as expected. Check the FRC Default Code Reference Guide for specific functions and IO mapping.
Unread 23-01-2004, 16:47
tml240's Avatar
bahh
Thanx for the info but we are still having trouble with the code and our robot. I was wondering if u edited or changed the defauls code in any way before putting it on the bot? cause we were having a lot of trouble. another thing i was just wondering was r u guys using one joystick for ur bot or r u guys using 2???? and for my finial question i was wondering how u guys set up the motors for ur wheels( like in which pwm output pin u put them in?) all ur help is greatly appreciated. thanx
Unread 23-01-2004, 16:55
Guest
Posts: n/a
What EXACTLY is the problem?
Unread 23-01-2004, 18:12
tml240's Avatar
bahh
if we load the default code onto the robot, the joystick is messed, x and y are switched, do u see that problem?
Unread 23-01-2004, 22:36
billstu billstu is offline
billstu is an unknown quantity at this point
I've seen it (left right on the joystick swapped)... but that should be easy to fix in the code...
Unread 24-01-2004, 09:55
tml240's Avatar
bahh
we are trying to fix this part:
pwm13 = pwm14 = Limit_Mix(2000+ p1_y + p1_x - 127);
pwm15 = pwm16 = Limit_Mix(2000+ p1_y - p1_x + 127);
ok here's the thing...
pwm 13 and 14 should be on one side and 15 and 16 on the other,
but we got 13 and 15, and 14 and 16.
so what can be fixed in the code?
Unread 24-01-2004, 10:22
BSEE, MSEE, JD
AKA: employed
nah never had a problem with the default code (make sure you are reading the default code reference guide if you are planning on hacking up the default code) either you are plugging in 13, 15, 14, and 16 wrong or the aliases for them are screwed up, check in "ifi_aliases.h" and check everything is ok in there......other than that im all out of ideas at the moment.....
Unread 24-01-2004, 10:50
Guest
Posts: n/a
Hardware problem?
First check what can't be fixed in the code:
Maybe somebody's already said this, but have you checked the connections from each PWM output to the Victor 884's? Then check the connections from the Victor's to the motors.
If you "fix" the code without fixing the hardware connections, your robot might work for now. But when somebody realizes that the connections are incorrect and fixes those, your robot will stop working and it'll be hard to debug.
Check software, hardware, then repeat.
Unread 24-01-2004, 11:28
tml240's Avatar
bahh
Re: Hardware problem?
bup forget it...we got it fixed....IT WAS THE WIRING! we are using two controllers to get the robot going...thx for the advices.... but we still need to control the speed, anyone got that?
Help On Coding 2K1 Controller GregTheGreat Programming 9 05-12-2003 18:35
serious problem found - robot controller resets when jarred! KenWittlief Electrical 23 19-03-2003 13:30
New software?? mjt902 Programming 2 08-01-2003 10:40
PBASIC 2.5 answer from Parallax JasonS Programming 6 07-01-2003 19:21
Team 237 unleashes a "Beast" Elgin Clock Robot Showcase 5 27-03-2002 21:09
