Go to Post Oh, you mean the refs. The only hand signal I've seen the judges use is the hi-five. - RoboMom [more]
Unread 25-01-2004, 23:51
Guest
Posts: n/a
Re: test autonomous mode
I was under the impression that input from the OI is ignored when in autonomous mode. So how did you get it out of auto mode?
how can you use a gyro in autonomous mode magical hands Programming 3 02-01-2004 13:31
Programming Autonomous mode Jared Stofflett Programming 3 11-11-2003 09:32
autonomous mode problem on field Chris_C Programming 17 26-03-2003 19:11
autonomous mode timer Don Programming 6 09-02-2003 22:16
autonomous mode? bigwalt Technical Discussion 1 21-01-2003 01:14
