Go to Post That makes it a winning move to, well, win. - EricH [more]
Unread 30-01-2004, 00:52
Larry Barello Larry Barello is offline
http://www.barello.net
#0492 (Titan Robotics Club)
Larry Barello has a spectacular aura aboutLarry Barello has a spectacular aura about
Re: Initializing autonomous mode
I have the system right in front of me and it prints out status and this is what it says:
When "disabled" the user code is in normal mode, running the normal mode loop, reading operator inputs, writing outputs, etc. but all outputs are disabled.
This is regardless of whether the autonomous switch is set or not (IFI dongle)
If the autonomous switch is set, the user code transitions into autonomous mode when the disable is removed.
test autonomous mode CharlieWilken Programming 14 20-02-2004 00:39
how can you use a gyro in autonomous mode magical hands Programming 3 02-01-2004 13:31
Programming Autonomous mode Jared Stofflett Programming 3 11-11-2003 09:32
autonomous mode problem on field Chris_C Programming 17 26-03-2003 19:11
autonomous mode timer Don Programming 6 09-02-2003 22:16
