Re: Interrupt timer, executing code asap?
technically, even fork() only does one thing at a time
it just interlaces the needs of multiple things, so that part of one function executes, then part of the next, et cetera.solution? no function in your bot code should last 5 seconds ![]() |
| Inserting Naviagation code into Default code? | actorindp | Programming | 3 | 28-01-2004 18:12 |
| Interrupts Questions | mightywombat | Programming | 0 | 03-01-2004 14:50 |
| EDU Demo Code: Serial Data Transmitter Using a State-Machine | Kevin Watson | Programming | 3 | 28-12-2003 22:56 |
| EDU Interrupt and Timer Template Code | Kevin Watson | Programming | 8 | 22-12-2003 14:11 |
| EDU Demo Code: Real-Time Clock Using a Timer | Kevin Watson | Programming | 1 | 17-12-2003 15:14 |
