Go to Post Another year, another picture of a Tytus injury. - Andy Baker [more]
View Poll Results: Have you let the magic smoke out?
Yes 8 24.24%
No 18 54.55%
We've come close 3 9.09%
What's a robot controller? 4 12.12%
Voters: 33. You may not vote on this poll
Unread 10-02-2004, 20:05
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: Anybody let the magic smoke out?
We messed up the RC pretty bad last year. Were were testing out the robot on tether and only had one half of the ramp up. Drove it up to the top of the ramp, then it accidentally launched itself off the cliff on the other side, tearing the tether port off the RC cause the cable wasn't long enough.
I wasn't there to see it, but I'm sure it was a rather embarrassing thing to have happen.
Unread 10-02-2004, 20:24
psychoCHIPMUNKK's Avatar
psychoCHIPMUNKK psychoCHIPMUNKK is offline
Technical Manager
#0241 (Last Minute Fix)
Team Role: Driver
psychoCHIPMUNKK has a little shameless behaviour in the past
Send a message via AIM to psychoCHIPMUNKK Send a message via Yahoo to psychoCHIPMUNKK
Our team tried to keep the robot from 2 years ago intact for practice...didn't quite work. I missed a day when we were taking off the un-needed components, and when i came back someone had managed to fry the RC by means of shorting out a Vic. Not fun
Team 241
Unread 10-02-2004, 20:25
Umm Errr...
Yup.
Last year:
Aluminum Shavings + Victor terminals = pretty sparks.
1139 Alumni
Unread 10-02-2004, 20:44
IMDWalrus's Avatar
IMDWalrus IMDWalrus is offline
This is a line...
AKA: Paul
FRC #0818 (Genesis '02)
IMDWalrus is a splendid one to beholdIMDWalrus is a splendid one to beholdIMDWalrus is a splendid one to beholdIMDWalrus is a splendid one to beholdIMDWalrus is a splendid one to beholdIMDWalrus is a splendid one to beholdIMDWalrus is a splendid one to behold
Send a message via AIM to IMDWalrus
Check back in tomorrow...that's when 818 will hopefully have this year's robot running...
I'm just a programmer, though - any magic smoke is not my fault. Not at all.
Unread 10-02-2004, 21:59
What about the magic noise in the mechanical parts?
most people are not aware that mechanical parts are made in machine shops where they are pumped full of noise (which is why machine shops are so loud)
the noise must only be let out of the parts a tiny little bit at a time - if the noise leaks out all at once the parts will fail. once all the noise has escaped from the parts you have to send them back to the machine shop to be pumped full of noise again.
With electrical parts its almost impossible to get the magic smoke back in, but with mechanical parts a skilled machinist can often pump it almost full of noise again.
One last thing, if a mechanical part fails on you, sometimes you can get a little bit of noise back into it by yelling at it, kicking it, or pounding on it with your fist. This might put enough back into it so it will work for a few more minutes.
Unread 10-02-2004, 23:58
aaronbr28040's Avatar
aaronbr28040 aaronbr28040 is offline
AKA: Aaron Bradshaw
#0900 (Team Infinity)
aaronbr28040 is just really niceaaronbr28040 is just really niceaaronbr28040 is just really niceaaronbr28040 is just really nice
Send a message via AIM to aaronbr28040
During the offseason I let the magic smoke out. I was working on one of the previous years robots and two of the pwm cable ends got together with the power on.......there was lots of smoke. PWM cable ends together= really bad news. The caqbles were melted together and I wasnt able to pull them apart. I let the magic smoke out of lots of things for fun though.......try a 12 ohm resistor at 30 VAC on an educational board so it is safe. Another idea for you teachers and tinkerers: try putting a burned out light bulb in a microwave until it explodes then leave the microwave running and watch the ball lightning come off of it. That wasnt my idea, i thought the robotics mentor/physics teacher was crazy at first for doing it but the result was awesome.
Even though I dont get hurt often I have gotten the reputation for doing crazy stuff in the lab. Its great to scare the juniors here at school by grabbing a hot 120 VAC wire. They get scared that you are going to release magic smoke, its great.
Unread 11-02-2004, 07:01
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Don't clicks and snaps from motors-with-rachets-being-driven-backwards release a lot of that noise at once?
Unread 11-02-2004, 00:09
deltacoder1020's Avatar
deltacoder1020 deltacoder1020 is offline
Computer Guy
AKA: Dav
#1020 (The Indiana Prank Monkeys)
deltacoder1020 has a spectacular aura aboutdeltacoder1020 has a spectacular aura about
Send a message via AIM to deltacoder1020
and this is why we never use the screw-in knobs on the tether cable better to have the tether fall out than to kill the port entirely
Team 1020, the Indiana Prank Monkeys (www.team1020.org)
Unread 11-02-2004, 00:58
steven114 steven114 is offline
Programming Wizard and Team Captain
AKA: Steven Schlansker
FRC #0114 (Eaglestrike)
steven114 is a jewel in the roughsteven114 is a jewel in the roughsteven114 is a jewel in the rough
Send a message via AIM to steven114
Just today I was using a computer power supply for a 5v power source, testing my sensor circuits. I accidentally touched the power and ground lines. Apparently the source isn't fused; immediately it heated up to the point that I couldn't touch it, and black smoke came off the alligator clips that I was using. The plastic sheath over them melted together before I could hit the off switch...
Unread 11-02-2004, 02:34
Pierson's Avatar
Pierson Pierson is offline
Pierson is a glorious beacon of lightPierson is a glorious beacon of lightPierson is a glorious beacon of lightPierson is a glorious beacon of lightPierson is a glorious beacon of lightPierson is a glorious beacon of light
Send a message via AIM to Pierson
We were doing speed tests this year, and hit the e-stop button before the robot hit anything. However, this caused the robot to do a front flip, and it landed upsides down after doing a front flip. We bent a couple bins on the RC. However (and thank goodness) we did not destoy it.
Pierson
Former Captain & Fundraiser of Team 360
Join in on these fun threads:
Three Worded Story
Word Association
Unread 11-02-2004, 06:34
pauluffel's Avatar
pauluffel pauluffel is offline
AKA: Paul Luffel
FRC #1127 (Lotus Robotics)
pauluffel is a jewel in the roughpauluffel is a jewel in the roughpauluffel is a jewel in the rough
Send a message via AIM to pauluffel
Yeah, earlier this year we burned up one of last year's extra 884's on our wooden prototype. Since the muffin fan on top kept spinning (and the log cabin we work in is quite drafty) the cloud of smoke had a wonderful shape to it. When we took off the fan to assess the damage, we found that three of the MOSFETs had huge cracks in them and several of the others were melted and mis-shapen.
It was not a good day for smoke, because a few minutes later the magic smoke escaped from our Dremel as well (but it was running low on noise already, the smoke was released in an attempt to get some noise and force back inside its motor).
Unread 11-02-2004, 12:57
The Lucas's Avatar
CaMOElot, it is a silly place
I think we fried the Analog Inputs on a controler for GeroniMOE last year. We hooked up hall-effect transistors (magnet actived transitors) with pull up resistors to sense embedded magnets in drive train sprockets. Our hope was to get a good readout of wheel revolutions but we noticed that those transistors and the gyro stopped working. The rest of the controller still worked so we put it on the practice bot (Sitting Bull) which didnt need a gyro.
Robot Inspector
Unread 11-02-2004, 17:56
Adam Y.'s Avatar
Adam Y. Adam Y. is offline
Adam Y.
no team (?????)
We did the same thing with the RS port. Fortunately we fixed it.
Magic David66 Chit-Chat 31 11-02-2004 00:13
Software Magic Smoke Al Skierkiewicz General Forum 17 30-04-2003 12:28
Magic The Gathering DarkRedDragon Chit-Chat 23 09-04-2003 09:10
Magic: TG meets Gulf War II DanL Chit-Chat 2 05-02-2003 12:48
Magic The Gathering SkitzoSmurf Chit-Chat 27 24-04-2002 15:05
