Go to Post Eventually, the "less effective" tweaks will settle to the bottom, and the more effective ones will be assimilated by the group. Then someone will tweak the tweak. That's when the fun begins. - Billfred [more]
Unread 24-02-2002, 20:41
Ranma Ranma is offline
#0831 (Ka Mikini O Hui Mililani)
Ranma is an unknown quantity at this point
Send a message via AIM to Ranma
Question Text effects in 3DS Max...
How do you make text transparent in 3DS Max? I've tried just about everything I can think of but nothing seems to work. Plus, the text has to fade in and out with the animation, so generally that involves changing the value of the alpha channel but you can't manipulate channels in 3DS Max like you can in Photoshop. We can always apply a transparent material like glass to the text but we want the opacity to change over time, and we don't want the text to be affected by any lighting or anything. I can't figure out how to do it in 3DS Max, but as a last resort we will use Final Cut Pro to add it in or even Flash if we have to. So please help someone! Don't make us use our last resort! Thank you.
All Programs Hate 3ds max LBK Rules 3D Animation and Competition 1 12-03-2003 22:31
Importing inventor files to 3ds max.... I found it!!!!! Tyler Olds 3D Animation and Competition 0 21-01-2003 19:16
3ds max VS Maya VS XSI DisTurbed 3D Animation and Competition 7 08-08-2002 22:52
Another 3ds max "Key" Jack 3D Animation and Competition 7 09-05-2002 21:19
Autodesk Inventor -> 3ds Max (File Format) Adrian Wong Inventor 1 22-01-2002 23:06
