Go to Post This is a once in a life time event for many of you guys. ENJOY it! - Tom Line [more]
Unread 28-02-2002, 21:31
Daishichimaru Daishichimaru is offline
Daishichimaru is an unknown quantity at this point
Send a message via AIM to Daishichimaru
Not really...
Animating the opacity works, yes, but it creates more side effects than it's worth. Screwing with the material opacity doesn't touch specular levels, so you can have transparent text and a big specular flare blocking everything from your 'invisible' text. This can be solved by wiring the parameters together, but then you can't play with either value independently and if you have opacity mapped with anything it doesn't work well at all. The visibility controller acts independently of texture channels and actually mutes the specular levels automatically. It's also a lot easier to get rid of the changes if you so decide when you can just delete a controller instead of key hunting. Just something to keep in mind.
Man is the ape that laughs.
All Programs Hate 3ds max LBK Rules 3D Animation and Competition 1 12-03-2003 22:31
Importing inventor files to 3ds max.... I found it!!!!! Tyler Olds 3D Animation and Competition 0 21-01-2003 19:16
3ds max VS Maya VS XSI DisTurbed 3D Animation and Competition 7 08-08-2002 22:52
Another 3ds max "Key" Jack 3D Animation and Competition 7 09-05-2002 21:19
Autodesk Inventor -> 3ds Max (File Format) Adrian Wong Inventor 1 22-01-2002 23:06
