Go to Post I'm still thinking about the 1114 469 doomsday.. I mean, that alliance has national champion written all over it. - Joel J [more]
Unread 24-02-2002, 20:41
Ranma Ranma is offline
#0831 (Ka Mikini O Hui Mililani)
Ranma is an unknown quantity at this point
Send a message via AIM to Ranma
Question Text effects in 3DS Max...
How do you make text transparent in 3DS Max? I've tried just about everything I can think of but nothing seems to work. Plus, the text has to fade in and out with the animation, so generally that involves changing the value of the alpha channel but you can't manipulate channels in 3DS Max like you can in Photoshop. We can always apply a transparent material like glass to the text but we want the opacity to change over time, and we don't want the text to be affected by any lighting or anything. I can't figure out how to do it in 3DS Max, but as a last resort we will use Final Cut Pro to add it in or even Flash if we have to. So please help someone! Don't make us use our last resort! Thank you.
Unread 24-02-2002, 22:00
Daishichimaru Daishichimaru is offline
Daishichimaru is an unknown quantity at this point
Send a message via AIM to Daishichimaru
Track view, find your text object, apply a visibility track, animate the values between 1 and 0 for opaque/transparent. Transparent being 0 and opaque being 1.
Man is the ape that laughs.
Unread 24-02-2002, 23:38
DOOMO ARIGATOU GOZAIMASHITA!!!
Unread 26-02-2002, 19:47
ComBBAT_Albrot's Avatar
ComBBAT_Albrot ComBBAT_Albrot is offline
#0021 (ComBBAT)
ComBBAT_Albrot is an unknown quantity at this point
Send a message via AIM to ComBBAT_Albrot
There's actually a far simpler way to do that...
Just apply a material to the text, then animate the opacity... it animates just like any other feature in the program, just make sure you have the Animate button on and you're on the right frame.
Unread 28-02-2002, 21:31
Not really...
Animating the opacity works, yes, but it creates more side effects than it's worth. Screwing with the material opacity doesn't touch specular levels, so you can have transparent text and a big specular flare blocking everything from your 'invisible' text. This can be solved by wiring the parameters together, but then you can't play with either value independently and if you have opacity mapped with anything it doesn't work well at all. The visibility controller acts independently of texture channels and actually mutes the specular levels automatically. It's also a lot easier to get rid of the changes if you so decide when you can just delete a controller instead of key hunting. Just something to keep in mind.
Unread 28-02-2002, 21:33
#0021 (ComBBAT)
Very true, but I was working from the standpoint that a lot of teams seem to be coming from. A lot of people I've spoken to don't use track view, or even really know about its existence.
Thanks for the info, though.
Unread 28-02-2002, 21:56
It's true that not a lot of teams know about the track view; I knew about it but I had no idea what it was until Daishichimaru told me what I can do in it. But it's not that hard to do the fade in/fade out effect anyways...so for some teams it might be easier one way, but we're doing it using track view.
All Programs Hate 3ds max LBK Rules 3D Animation and Competition 1 12-03-2003 22:31
Importing inventor files to 3ds max.... I found it!!!!! Tyler Olds 3D Animation and Competition 0 21-01-2003 19:16
3ds max VS Maya VS XSI DisTurbed 3D Animation and Competition 7 08-08-2002 22:52
Another 3ds max "Key" Jack 3D Animation and Competition 7 09-05-2002 21:19
Autodesk Inventor -> 3ds Max (File Format) Adrian Wong Inventor 1 22-01-2002 23:06
