Go to Post The strength of an alliance is not defined strictly by the sum of its parts. - Jared Russell [more]
Unread 24-02-2004, 16:50
deltacoder1020's Avatar
deltacoder1020 deltacoder1020 is offline
Computer Guy
AKA: Dav
#1020 (The Indiana Prank Monkeys)
deltacoder1020 has a spectacular aura aboutdeltacoder1020 has a spectacular aura about
Send a message via AIM to deltacoder1020
Re: Simple Autonomous Mode Example
Originally Posted by Astronouth7303
You know, I'm doing basically the same thing using simpler code. Plus, You can write REALLY LONG scripts without REALLY lengthening the code. I'll Release my source about a week or 2 after regionals.
Hint: Arrays
arrays indeed - if i myself were actually using dead reckoning, chances are I'd be using the approach I'm guessing you're hinting at. In this instance, however, I'm really just trying to make the code as straightforward as possible, so this seemed like a better idea.
Team 1020, the Indiana Prank Monkeys (www.team1020.org)
Initializing autonomous mode Mr. Lim Programming 7 02-02-2004 07:26
how can you use a gyro in autonomous mode magical hands Programming 3 02-01-2004 13:31
Programming Autonomous mode Jared Stofflett Programming 3 11-11-2003 09:32
autonomous mode problem on field Chris_C Programming 17 26-03-2003 19:11
autonomous mode timer Don Programming 6 09-02-2003 22:16
