Go to Post The first was a fish, all silver and spotted. “An opah?” I asked. “Yes,” my friend nodded. I knew not what it meant as I sat there and stared, But I appreciated the thoughts that the posters had shared. - Robotics692 [more]
Unread 01-03-2002, 18:01
GhettoTech GhettoTech is offline
#0300 (Ghetto Techs)
GhettoTech is an unknown quantity at this point
Send a message via AIM to GhettoTech
if p1_sw_trig = 1 then PWM12 = 150
Just a little note. That won't work in PBasic. PBasic's If/Then statemtents include an automatic "Goto."
If p1_sw_trig = 1 then (Goto) is implied
If p1_sw_trig = 0 then skip:
PWM12 = 150
skip:
that would be one way to work around that problem. (Similar to how the PWM limit switches are programed)
serious problem found - robot controller resets when jarred! KenWittlief Electrical 23 19-03-2003 13:30
How do you connect the speed controller fans? Iain Electrical 7 31-01-2003 07:05
Speed controller fan replacement Rickertsen2 Electrical 11 16-01-2003 08:46
Speed Controller Limits yaman Technical Discussion 11 15-01-2003 18:40
Ugh...PWM pin vs. Speed Controller archiver 2001 1 24-06-2002 00:27
