Go to Post "We've got more money than brains." - Travis Hoffman [more]
Unread 28-02-2002, 08:15
Raul's Avatar Unsung FIRST Hero
Raul Raul is offline
Somewhat Useful Person
no team (Formerly - Wildstang)
Raul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond repute
Cool WildStang Videos
Check these out at:
http://www.wildstang.com/2001/video/video2002.htm
Comments?
Warning: this reply is just an approximation of what I meant to convey - engineers cannot possibly use just written words to express what they are thinking.
Unread 28-02-2002, 08:48
Ken Leung's Avatar Unsung FIRST Hero
Ken Leung Ken Leung is offline
Dare to Live!
FRC #0115 (Monta Vista Robotics Team)
Ken Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond repute
Send a message via AIM to Ken Leung
Re: WildStang Videos
Originally posted by Raul
Check these out at:
Comments?
VERY COOL swerve movement. Although I thought last year's music was better, I like this year's robot better
With this kind of swerve movement, it should be really easy to get the balls with your ball collector. I especially like how you shoot the balls into the goal. Looks like the whole robot can store only about 12 balls, but the speed of dumping balls into goal compensate for that.
Is it hard to control the robot? I have always wondered how to successfully control a swerve drive... But it looks like the driver perfected their skills and the robot can grab the goal and balls easy. I see it can grab two goals, maybe even three if it wants to. Not especially fast speed, but plenty of pushing force and great maneuverability.
Should be your most complicated robot... Great job! Hope to see it in video, or at National. There is no question whether this bot is going into finals or not. There should be a spot reserve for you in the Championship event finals. With enough luck, you might find a good enough alliance partner in your division to push you far into finals.
Too bad you have to damage your last year's robot at the end of the video
Unread 01-03-2002, 00:10
Wetzel's Avatar
Wetzel Wetzel is offline
DC Robotics
FRC #2914 (Tiger Pride)
Wetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond repute
Send a message via AIM to Wetzel
Nice. Just the one joystick? Or am I confused after looking at to many control systems today...
Viva Olancho!
Unread 02-03-2002, 20:02
Don's Avatar
Don Don is offline
#0288 (the RoboDawgs)
Don is an unknown quantity at this point
Send a message via AIM to Don
I am wondering about your drivetrain. I see the wheels that you use for your swerve drive, but looking at some pictures I also see that you have a small track system with cleats, powered by two chiphua motors. Is that an old design or are you somehow incorporating both? How does it work?
Unread 02-03-2002, 20:11
Wetzel's Avatar
DC Robotics
I didn't notice that, but I went and looked at the photo gallery. From watching you move crab like, I assume that the treads rise up off the floor to crab, and lower for traction?
I also couldn't find a good pic of it on the bot, but I think I saw it burried in the middle.
Viva Olancho!
Unread 03-03-2002, 03:37
Tank Drive
Yes, it is an auxillary tank drive system. It gets deployed (lowered to the ground and actually raises the robot off its wheels) when we want to push hard. I am about to tell you more than you probably care to know about it.
It is geared down to the point where it can only move 8 inches per second max. It can produce approximately 2000 lbs of trust at stall. Needless to say, it will never stall - its not really possible to get enough traction to do that.
We would obviously only use it when we get in a pushing match when attached to a goal that is lifted enough to transfer some weight to our frame. We did not use it much in our practice competition. We only used it as an anchor so we could not be moved when we were happy with our position.
By itself it looks like a mini tank robot. There are lots of pictures of it here (its is a spare one we built): http://www2.wildstang.com/2002/invit...2002_page2.asp
You can navigate around our website and see lots more pictures and videos.
It is very modular. We can remove it by removing 2 pins, the seatmotor flex shaft which raises and lowers it and disconnecting the motor wires. It weighs about 16 lbs. So we can remove it when we want to add some other functionality and still be within the legal weight limits.
Its mounting scheme allows it to swivel in two independent axis so that it can always maintain flat contact with the carpet.
I hope that is enough details. We will have the spare to show at the competitions we attend.
Unread 03-03-2002, 12:35
meaubry meaubry is offline
volunteer helper
FRC #6099 (Knights)
meaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond repute
very nice
Raul,
Very impressive (as we are used to from you guys) Good Luck this year, Hope to get aligned with you many times. Oh, by the way - do you have to weigh in multiple times with various combinations of modules or can you weigh in once with all the stuff attached?
Unread 03-03-2002, 13:52
Matt Reiland's Avatar
'The' drive behind the drive
I am again amazed at how much stuff you guys get in there for 130 lbs.
Unread 03-03-2002, 17:25
Thanks Matt.
Mike,
We had to weigh ourselves 3 times last year during our inspection to cover our 3 possible configurations. Depending on how things go this year, we may have up to 5 unique combinations that we will have to weigh in with. But I doubt we will sue that many throughout any competition. The combinations we use will depend on strategy and what is working well to help us win with certain partners.
Our modular components are:
- Tank drive
- 2 goal hooks
- Ball accumulator and shooter
- Ball plow/concentrator
- "go-home device"
Some of these modules change out very quickly - like the hooks. Others can take a few minutes.
The last two need to be finished at the competition and the "go-home" device may not be used at all. This depends on how refs call entanglement in previous competitions - we will be watching this closely to decide if it will be a legal device or not.
Unread 03-03-2002, 19:47
Mike Soukup's Avatar
Mike Soukup Mike Soukup is offline
Software guy
FRC #0111 (Wildstang)
Mike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond repute
2 drive sticks
I hope I'm not giving away any trade secrets, but I doubt it since many teams have developed their own crab / swerve drive.
The driver uses 2 joysticks. The right stick is a cross between a standard 1 stick robot drive and a car - forward moves the bot forward, back moves it backwards, right turns the front wheels right and the back wheels left, and left does the opposite. The left stick controls crab - move it left and all four wheels turn left, move it right and all four wheels turn right. Each crab motor has a feedback loop so when the driver moves the crab stick 1/2 way to the left, the wheels turn 45 degrees left and stop.
It's a lot easier to control than you may think. After an 30 mins, anyone used to driving a standard single stick drive would be fairly comfortable on it. Mastering the drive is another story, that takes time.
Mike
Unread 04-03-2002, 22:58
Kevin Ray's Avatar
Kevin Ray Kevin Ray is offline
None #0329 (Raiders)
Kevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to behold
You guys should be this year's poster team for Inspiration. You define what FIRST is looking for. Great robot, can't wait to see it up at the Nats.
Unread 05-03-2002, 08:31
foursixnine foursixnine is offline
#0469 (Las Guerrillas)
foursixnine is an unknown quantity at this point
Send a message via AIM to foursixnine
Not working
Maybe it's just my computer but I couldn't get the first video(Beware of Wildstang) to work maybe the link is broken.
Unread 06-03-2002, 08:28
Unhappy
Try doing a right click on the link and pick "Save Target As". Then run it from your computer.
Unread 06-03-2002, 09:07
Dare to Live!
Question few questions...
I got a few questions about the robot, after watching all the cool videos...
1. Is this the most complicated robot you've ever built?
2. How many goals can you get? 2 or 3?
3. What makes you decide how much balls this robot is going to hold? Was it weight, space, resources, strategy?
4. How many motors are you using? (I heard all except the torque!) And how do you deal with drawing too much current?
And the question I want answer the most:
5. Why why why are your robots so cool looking all these years?
Unread 06-03-2002, 12:09
Software guy
Re: few questions...
No idea, but it sure does look complicated.
We are limited to two because we use the window motors to drive our hooks. We can put the two hooks in any of 3 places: back, right, & left.
This was dictated by strategy. Some on the team wanted only a couple of balls. Others wanted a lot. We compromised on ~12.
Yes, we're using all the motors except the torque motor. Don't quote me on this, but I think we can get away with this because we don't use them all at once, and they usually aren't under heavy load. Obviously the 4 drive motors & the two crab motors get a lot of use and are under large loads. The tank motors will have a big load, but we usually won't be running many other motors when these are going. The window motors that control the hooks don't get run much at all. And the motors for the accumulator / convayer / shooter do not have much of a load and are almost spinning freely.
This is an easy one. It must be because of the software team. Sorry Raul, I couldn't resist. Seriously, it's because we have some outstanding mechanical engineers & students who come up with good designs, and we have the resources to turn those designs into a real robot.
Mike
Wildstang and WASH 2003, We need your help! BrianUlmer Scouting 0 31-01-2003 16:41
Wildstang Cubs game @ Wrigley (6/26) archiver 2001 2 24-06-2002 04:13
Digital videos archiver 2001 1 24-06-2002 03:57
Video from the WildStang Invitational... archiver 2001 3 24-06-2002 01:12
videos needed archiver 1999 3 23-06-2002 22:09
