Go to Post By "resources" do you mean money (sponsor or school), school support or permission, build facilities, or mentors? All of these require different solutions. - Carol [more]
Unread 06-03-2002, 22:14
Wayne C.'s Avatar Unsung FIRST Hero
Wayne C. Wayne C. is offline
hey- I think we did pretty good?
FRC #0025 (Raider Robotix)
Wayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond repute
Thumbs up yes- there is a send home device out there which works...
we have a send home device made of sections of linked 1' square tubular aluminum sections which pull out 30 feet. It has been thoroughly tested and it works like a dream, reliably. This "arm", while it runs on small wheels along the floor, is fairly rigid and should be high enough above the carpet not to be considered an entanglement. As described below- it is flimsy, as any arm 30 ft long deploying from a 3 ft box would be!. It is also easily changeable between rounds and others have been made to replace it should a rambunctious opponent get malicious.
In FRC Engineer update 144 I quote- "A telescoping arm, given sufficient lack of sharp features etc, would likely not present entanglement but might prove flimsy and unreliable. The ultimate determination of what presents a risk of entanglement is made by inspectors at each event"
To me it sounds like the INSPECTORS who clear the robot for competition will not let it enter the field if it is deemed an entanglement. It also sounds like there will be a great deal of inconsistency from regional to regional. At the NH kickoff Kamen offered "Kamen points" for a robot which could score in both end zones. We can do that easily
If there is a disqualification for us we do have an alternative device to replace the arm. But quite frankly it will make us play another strategy which I am CERTAIN our opponents will not like.
I would like to know whether all these judges at the pregame events we've been hearing about are actually FIRST certified inspectors and are totally familiar with all the fine points the FRC engineers gave us during the season?
Should they be used? Certainly!! Unless you have another way to simultaneously control two goals on the field and get the additional 10 pts.
My $.04 worth
WC
Well, I just got home. archiver 2001 2 24-06-2002 01:08
Mountain Home & 'The Brawl' archiver 2000 0 23-06-2002 23:20
Send me your pictures! archiver 2000 0 23-06-2002 22:02
Goal moving devices fs_2002 Technical Discussion 5 27-01-2002 19:55
Taking the kits from Manchester on planes back to home base Ken Leung General Forum 4 24-09-2001 22:47
