Go to Post Why subject your robot to a potential sensor failure when you can train a monkey (or a student, if monkeys are lacking) to put the tube at the right height every time? - JVN [more]
Unread 08-03-2002, 09:41
megabass31 megabass31 is offline
megabass31 is an unknown quantity at this point
Entanglement Ruling at VCU
According to the officials at the VCU Regional, for bots with devices that can reach into other zones. They would not block any such device. However, if the devices goes under the goals, it is a DQ. If someone intentionally pushes a goal over the device, it would appear to be a DQ. So good luck to all and be careful.
Unread 08-03-2002, 10:28
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
DQ for WHO?
Which team gets DQ'd? The team under the goal or the team that pushed the goal on top of the team?
Joe J.
Unread 08-03-2002, 10:40
The team who pushed the goal on top of the device, but this is only if it is intentional.
Unread 08-03-2002, 10:45
AKA: Dr. Joe
FRC #0088 (TJ2)
This is fair?
It seems to me that a team that wants to divide the field in half then just has to put a device right down the middle of the field.
Forget about trying to win a pushing match, just get the goals where you need them and open up on the ground making it impossible to move the goals without having the goal get over my robot. Any team that tries to move the goals gets DQ.
This seems to be a ruling that is not quite ready for prime time...
Am I missing something?
Joe J.
Unread 08-03-2002, 10:52
I'm just reporting what I saw on the stream from the competition. It sounds like all of this is a judgement call on the part of the refs. But I did see on robot do something very similar to what you talked about. The team basically had their bot do a spread-eagle formation. It had two arms out-stretched to try and stop any goals from entering the goal zone, with an extension back to their home zone. It seemed like a good idea, but I wondered about any rules violation with this. It almost worked also, but one of the goals was just barely in the goal zone which gave the other alliance the ten point victory in the match. Oh well, good luck to all.
Unread 08-03-2002, 12:37
Sean_330's Avatar
Sean_330 Sean_330 is offline
SoCal Pride!!!!!!!!!!
#0330 (Beach Bot V 4.0)
Sean_330 is on a distinguished road
Send a message via AIM to Sean_330
What about if a robot and not a goal gets caught up on the send home device?
Unread 08-03-2002, 18:16
ahecht's Avatar
ahecht ahecht is offline
'Luzer'
AKA: Zan
I hope FIRST plans on putting out an Update if there is an official ruling on this. It would sure take a load off of our back (and off the judges' back).
Zan Hecht
Unread 08-03-2002, 18:28
FRC Key Volunteer Trainer
AKA: CrazyNate
Rest Easy Joe...
Joe J.
My recollection of the announcement this morning was that the DQ would only occur if, in pushing a goal over a robot's extended arm, damage occurred to the goal as a direct result of pushing it over the mechanism. Now, based on what comes to mind right now, damage to a robot would result before damage to a goal in just about any "push over" case, unless the robot was specifically designed to damage a goal if it was pushed over. In this case, I have a feeling the mechanism would be disallowed under the "intentional damage" rule.
Nate Smith
nsmith@smythsoft.com
Unread 08-03-2002, 18:30
AKA: CrazyNate
One thing I've learned during my 4(not counting this year) years in this...not often will, once the regionals start, an official update be posted. Rather, any rulings that affect future events will be announced at the beginning of subsequent events. Keep your ears open when you head off to your first regional, and bring printouts from FRCTech regarding anything you think may be an issue for your team's design or strategy.
Nate Smith
Unread 08-03-2002, 20:59
Matt Reiland's Avatar
'The' drive behind the drive
I hope that a send home device is not 'off limits' to everything out on the playing field, if thats the case in our parts modification time after the regional we will take of the goal grabber and ball grabber and put 10 return to home devices in a star pattern an nobody on the field can move. right??!!! I hope that the ruling from megabass was a special case with other circumstances.
I still fell that any of these long devices are just an extension of the robot and they shouldn't get any other special treatment just like a goal grabber or ball grabber. I really hope first notices this as well otherwise I am going to be busy after our first reigonal
Unread 08-03-2002, 21:21
Kevin Ray's Avatar
Kevin Ray Kevin Ray is offline
None #0329 (Raiders)
Kevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to behold
We have a send home device and, believe it or not, I agree with you Matt!! I don't want any special treatment for the device or its tether for that matter. I think that its part of the robot and should be treated as such. If it's not robust enough, well... that's life and you'll be sure to improve upon that design next time.
What I do hope though, is that the judges are equally easy going when it comes to the tangling issue. Scenario: team "A" has a dual extensions designed to grab three goals (moe) for example, if I get hung up on it, well it's too bad for me--there are no provisions for that. And he is dividing up the field as well. Now, I send home my Jerry mouse (Tom & Jerry) and "A" 's partner gets hung up on my tether. I'm DQ'd and "A" isn't. Would that be fair? We're still talking about extensions of a robot in both cases.
Food for thought.
Unread 09-03-2002, 01:27
ahecht's Avatar
'Luzer'
AKA: Zan
This sounds like the judges might have just been restating Team Update #6, which said:
Q) If there is some situation that such a case would be legal, would such a robot be found in violation of rule that prohibits going under the goal (GM20) if the goal was pushed up over the tether by another robot?
A) This would not be a violation of GM20, because the robot did not intentionally put the tether under the goal. However, the alliance pushing the goal over the robot could be penalized if damage to the goal was deemed likely to occur as a result of passing the goal over a robot.
Zan Hecht
Unread 09-03-2002, 09:08
I hope you are right ahecht that its the goal being damaged that they are worring about. I for 1 will be impressed if someone can ruin one of the goals with thier robot or drive the goal over someone else (I am sure one of the lifters might try it!!)
Unread 10-03-2002, 19:33
gniticxe's Avatar
gniticxe gniticxe is offline
B.C.O.M. Forever!
AKA: Brian Gattman
no team (FRC2910 - Jack in the Bot / FRC365 - MOE)
gniticxe will become famous soon enough
Nothing to fear...
In our match against 384 sparky 3.0, the center goal was pushed on top of our chassis such that the bottom plywood was over part of our 'low rider' frame. We were DQ'd for attaching to the center goal under the bottom plywood, as it is detailed in the rule book. I think this was a fair ruling, and it goes along with what people here seem to think as well.
Unread 10-03-2002, 19:44
Joe Matt's Avatar
Joe Matt Joe Matt is offline
Wake Up Get Up Get Out There
Joe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond repute
Thanks for the fun . You guyes were awsome and derserved to be recognized. Great feat of engenering. You guyes also deserved to win the image award. Thank god we were next to you, the orange and kaki sofened the green . Also thanks so you didn't brutily mutilate us because of that rueling. I didn't know that was the reason untill Gabe posteded it up here on the MOEhawk vs. Sparky 3.0 thread. Enjoy Philly and see you at EPCOT!!!!!
Q&A Discuss: Tethering without being entanglement CD47-Bot Extra Discussion 2 06-01-2003 14:10
entanglement roboticscom13 General Forum 27 30-03-2002 23:23
Can any VCU teams help me?/ VCU thanx DUCKIE Thanks and/or Congrats 0 13-03-2002 10:17
Numbers at VCU Madison Regional Competitions 5 10-03-2002 02:26
Can we stand one more thread on entanglement? Joe Johnson Rules/Strategy 6 17-01-2002 11:33
