Go to Post Be civil in all things and you will get far. - Wetzel [more]
Unread 16-03-2004, 08:17
seanwitte seanwitte is offline
None #0116
seanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant future
Send a message via AIM to seanwitte
Re: Future of Autonomous Mode
Its pretty easy to integrate a program running on a PC with the mini-RC using the serial port. You can code all of your low-level functions on the RC with any high-level processing on the PC. The PC handles all of your "big picture" task management and the RC handles IO and actuator control. Your PC program is basically acting as a smart operator in teleoperation mode. You could probably mount a small laptop on a simple mobile robot base or use a wireless serial adaptor.
Obviously you won't be able to use this on the real robot for the FRC, but what are you going to do for the other 46 weeks of the year?
setting autonomous mode Allison Programming 10 08-03-2004 20:37
Initializing autonomous mode Mr. Lim Programming 7 02-02-2004 07:26
how can you use a gyro in autonomous mode magical hands Programming 3 02-01-2004 13:31
autonomous mode problem on field Chris_C Programming 17 26-03-2003 19:11
autonomous mode timer Don Programming 6 09-02-2003 22:16
