#14
Re: counting in seconds for the autonomous mode??
hmmmm.... I dont understand TedPs adversion to counting SW loops.
someone has tested the timing of the statusflag.NEW_SPI_DATA event- its controlled by a timer in the communications loop and testing has shown its dead accurate every time, unless you have so much code that it takes more than 26mS seconds to execute. statusflag.NEW_SPI_DATA will be true 38 times a second - you can even round it off to 40 to make it simpler - I cant imagine anyone needing finer resolution that 1/38th of a second while setting up the sequence of events in auton mode ? |
| Future of Autonomous Mode | FadyS. | Programming | 41 | 24-05-2004 19:45 |
| Simple Autonomous Mode Example | deltacoder1020 | Programming | 5 | 08-03-2004 20:22 |
| Initializing autonomous mode | Mr. Lim | Programming | 7 | 02-02-2004 07:26 |
| autonomous mode problem on field | Chris_C | Programming | 17 | 26-03-2003 19:11 |
| autonomous mode timer | Don | Programming | 6 | 09-02-2003 22:16 |
