Go to Post As long as this is a competition teams will push the limits. Those that succeed are those who can push the envelope and still stay within the lines. - Steve W [more]
Unread 31-03-2004, 14:18
omega's Avatar
omega omega is offline
omega is an unknown quantity at this point
Re: heres the code. y this not working
ya uh we need more help then that
thz anymore
Unread 31-03-2004, 15:18
DKolberg DKolberg is offline
Mentor Iron Giants
AKA: David Kolberg
FRC #5069 (Iron Giants)
DKolberg has a spectacular aura aboutDKolberg has a spectacular aura about
/* Add your own autonomous code here. */
Navigate();
if(rc_dig_in01 ==1 )
pwm13 = 137;
pwm14=100;
else
pwm13 = pwm14 = 140;
if(rc_dig_in02 == 1)
pwm13 = 100;
pwm14 = 137;
else
This code will ignore the rc_dig_in01 as the if(rc_dig_in02 == 1) overwrites the values. You need to create 4 states for this or at least determine what you want to happen for each of the 4 states that can happen with two digital inputs:
rc_dig_in01 == 0, rc_dig_in02 == 0
rc_dig_in01 == 0, rc_dig_in02 == 1
rc_dig_in01 == 1, rc_dig_in02 == 0
rc_dig_in01 == 1, rc_dig_in02 == 1
I assume here that these are the inputs from a light sensor that indicates which light is seeing the tape, depending on how far away each sensor is it may not be possible to get both on at the same time. Then you are down to only 3 states. For simplicity lets define
Left == (rc_dig_in01 == 1);
Right == (rc_dig_in02 ==1);
Now:
if (Left)
turn right
else if (right)
turn left
else
go straight
if both left and right can be on at the same time then check for that first
if (Left && Right)
else if (Left)
else if (Right)
else
Hope this helps,
Dave
SBotz
What is your most prefered programming language? Hailfire Programming 156 19-01-2005 21:42
Speed limiting code from last year in C? Josh Siegel Programming 6 01-04-2004 22:27
Interrupt timer, executing code asap? SeanCassidy Programming 10 07-03-2004 01:47
Does your team use the Default code. Jeff McCune General Forum 2 09-01-2003 14:46
