Go to Post EVERYONE on the team is offered the same opportunities to be a team player, it is up to each person to step up and play the game. - MariaCastro [more]
Unread 17-03-2002, 17:26
John Prather John Prather is offline
#0234 (Cyber Blue)
John Prather is an unknown quantity at this point
Send a message via Yahoo to John Prather
Best strategy for Finals
I'm not sure, but is going for all three goals really the best stategy for the Finals??????
Would having two really good ball bots with one of them being able to grab 1 goal, control it, defend it, and both bots filling it up with balls be better?
If you got more than 20 balls, you would already have more points than you ever could just being able to grab and control 3 goals. With 2 really good ball bots this wouldn't be a problem.
John Prather
Team 234
Student/Electronics/Controls/Programs/Scouting Team
Unread 17-03-2002, 18:22
Joel J's Avatar
Joel J Joel J is offline
do you..
You are correct. If you get one goal, 21+ balls, and a robot in the end zone, you most likely won.
Joel Johnson
RAGE (173) Alumni, 1999-2003
Unread 17-03-2002, 19:57
Jeff Waegelin's Avatar
El Jefe de 148
AKA: Midwest Refugee
FRC #0148 (Robowranglers)
Well, I do not know if grabbing three goals is the best strategy, but it definitely worked for us. We won six out of seven elimination matches in Cleveland with our wonderful partners, 469 and 859, and didn't have too much trouble achieving that. We had some quick and easy matches, and we had some close matches that came down to a final last minute push, but overall the strategy was a great success.
I think that the strategy Joel and John are discussing would work, but the key element is holding that goal (as it is for any strategy). If you lose your 1 goal, you lose. It would be very easy to block a ball team off and prevent them from scoring their points, or just push them back. If you control all 3 goals, however, you are guaranteed a win. Without goals, victory is impossible.
That's not to say balls (and ball teams) are not important. In qualifying, they are VERY important, and in a close match, a few balls can be the deciding factor. My point, however, is that in elimination rounds, goal control is more important, and balls play second fiddle to goals. Of our winning alliance in Cleveland, all three teams were goals-only. While balls could have helped, they are not a necessity to win matches. Without goals, balls are nothing.
Jeff Waegelin
Unread 17-03-2002, 21:20
meaubry meaubry is offline
volunteer helper
FRC #6099 (Knights)
meaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond repute
Jeff,
You make a good point, but the major element is time and alot of "if's"! By the way, your alliance was awesome and you all did a great job, congrats.
To ward off the "tug o war" double goal handlers, the Single goal grabbers must be faster to the goal and also more manueverable with it once it has it - two minutes is an eternity when a relentless slower machine is uninhibited in its progress. I suppose the partners could block it and just give up on trying to keep the other team from taking 2 - you can't loose 3 unless you are pretty sure that you can block it into your scoring zone.
The key to keeping out of trouble in the first place is to beat the other team to the goals, latch and turn (rotate away from the other goal) at the same time - so the other team doesn't get the goal practically brought to them. At least you have to make them work to catch it -
I can't wait to see 2 very fast double goal grabbers smash head long into the goals at the same time and the same opening - now that may lead to some interesting results!
Unread 17-03-2002, 21:38
El Jefe de 148
Thank you very much, meaubry. I really enjoyed playing against your team. The excitement on the field for those matches and all the other elims was amazing.
The key to pulling such a strategy off is to have two machines that can dash to the goals, get all three, and then be able to push to get the goals in scoring position. Ideally, teams with multi-speed transmissions would do this best, but if played right, that is not mandatory. More important is to be able is to outrun the other team for the first two goals and out push for the third. If a team is a strong enough pusher (like us) they can force a goal (and robot) to go anywhere they want.
Jeff Waegelin
Unread 17-03-2002, 21:54
Kevin Ray's Avatar
Kevin Ray Kevin Ray is offline
None #0329 (Raiders)
Kevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to behold
I agree that the tug of war is the best strategy, well... that's what I thought especially rounds the first weekend. After seeing several of the teams ( 173 especially) in the SBPLI regional I changed my mind. They and phenominal speed and hit the goal in seconds, locked on and proceeded to suck up every ball on their side. The have tenacious traction and "OWN" what ever goal they take. I think that what makes them successful is that they can manhandle the goal quickly, thus enabling them to avoil a tug of war. However, if that is unavoidable, I only saw them lose one of those and that was to a team who had a 1 ft/ sec. tractor.
So... is tug of war in the finals the way to go in the finals, most likely--unless there is a team like 173.
Unread 17-03-2002, 21:56
Kevin Ray's Avatar
Wow, I think that I should re-read what I type before I hit "send"
Unread 17-03-2002, 23:48
Natchez Natchez is offline
#0118 (Robonauts)
Natchez has a reputation beyond reputeNatchez has a reputation beyond reputeNatchez has a reputation beyond reputeNatchez has a reputation beyond reputeNatchez has a reputation beyond reputeNatchez has a reputation beyond reputeNatchez has a reputation beyond reputeNatchez has a reputation beyond reputeNatchez has a reputation beyond reputeNatchez has a reputation beyond reputeNatchez has a reputation beyond repute
Has anyone around the country tried or considered pulling/pushing the bi-goal or tri-goal "system" into their own end zone during elimination rounds? Granted, there are a million what-ifs (such as # balls in the goals, can the opponent get to their end zone while holding onto the goals, etc.) but it seems like a solid strategy.
Imagine, you find yourself in the finals against the most phenomenal 3 goal robot known to man teamed with a bulldozer 'bot. The crowd awed as this duo went undefeated in the quarters and semis by taking hold of the 3 goals and crawling them into the scoring zone while the best pusher 'bots were unsuccessful at trying to push them back up Mount Everest. Fortunately and unfortunately, you have the sparse crowd madly cheering for you because you are the biggest underdog that the world has ever known. But then the well-mentored future rocket scientist comes up with the strategy that the entire team begins to laugh at but then realizes that it just may be crazy enough to work. Her idea is to sneak around the tri-goal system and push the entire system into your end zone while blocking the sneaky little mini-me-bots (of course, named Minnie-me and Mickey-me) of the 3 goal dominators. You put the plan into action and the crowd starts to get up to leave with about 30 seconds left to go when a tremendous gasp that sucks the Epcot Ball from its pedestal and knocks all of the refs off their feet. The mumbling begins. "They're going to push everything into their own end zone!" "Wow, the bulldozer 'bot can't help!" "They'll win anyway because they have two balls in the goal and they have their Mickey-bot & Minnie-bot ... let's go to Epcot ... this thing's over." "Wait, they're blocking Mickey & Minnie." The buzzer sounds and you win the first match 30 to 2." Within 30 seconds, the buzz has made it back to the pits; everyone is running out the pit tents and into the stands to see if Goliath will fall. You look up in the stands to find that the previously sparse crowd of Disney clean-up personnel is now a standing room only stadium. As you catch your breath, you realize that your stomach that you thought was at full butterfly-capacity 4 minutes ago has just found a way to triple that number. What do you do now?
Unread 18-03-2002, 23:25
PMGRACER's Avatar
PMGRACER PMGRACER is offline
AKA: PAUL GIANNOSA
PMGRACER is on a distinguished road
The final mathes at the Buckeye were splended to watch! The Feds and Guerillas were awsome to watch in action! We only grabbed the goals once in high gear, which was at about the same speed the Guerillas could get to the goals. I think a match between 27 and 469 would be a lot of fun; once we get the bugs out of our shifter program! I love the way 469 gets on the goals, moves them to the end zone, spins the chasis 90 degrees and hangs out! Awesome! Nice machine, congratulations!!
Racing is an incurable addiction!!
Unread 19-03-2002, 08:16
President, VEX Robotics, Inc.
3 Goals are No Guarantee
As Natchez has eluded to ... 3 Goals does not guarantee a win!!
4 robots in your zone, 3 goals in their zone ... human player has to be 10 for 10 in order for the 3 goal team to win.
I know there are a lot of ifs, but the point is that 3 goals does not guarantee a win.
-Paul
Unread 19-03-2002, 10:57
Jason Haaga Jason Haaga is offline
no team (Royal Assault)
Jason Haaga is an unknown quantity at this point
Want to know the best strategy for the finals?
Wait till New Haven, you'll all see
Alum of RAGE173 2000-2003
Unread 19-03-2002, 14:36
Jeff Rodriguez Jeff Rodriguez is offline
Too young to be an 'old guy'
FRC #0155 (Technonuts)
Jeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond repute
Send a message via AIM to Jeff Rodriguez Send a message via Yahoo to Jeff Rodriguez
YES!! thank you, you're the first person i've seen that recognizes our ball & goal handing ability. Thank you so much. Everyone listen to this guy he knows what hes talking about
Unread 19-03-2002, 15:13
Steve Prairie's Avatar
Steve Prairie Steve Prairie is offline
Alumni
#0173 (RAGE Robotics)
Steve Prairie is on a distinguished road
Send a message via AIM to Steve Prairie
Ogre, they don't hafta listen to Kevin or us, they just hafta be prepared for when we fly by them with a basket full of balls and a goal in the finals. Who needs "best of 2 out of 3" when you can go back to back all the way?
Hopefully we can get some good video footage up soon...
Unread 19-03-2002, 17:29
Joel J's Avatar
do you..
I hate this, y'all are scaring me..be cool.
Joel Johnson
Unread 20-03-2002, 09:30
come on!! you know how you drive, just go with it. its much more fun.
173, student: 1999-2002
173, mentor: 2005-2010
155, teacher: 2011-
A good driver makes his own strategy. What do you think? archiver 2001 26 24-06-2002 02:21
200pt strategy. archiver 2001 12 24-06-2002 02:02
What's the best qualifying rounds strategy? Ken Leung General Forum 24 24-03-2002 18:25
This year's strategy smokescreen Rumor Mill 23 12-01-2002 19:56
Need help with strategy? Here's my team's method! Khalicl13 Rules/Strategy 4 10-01-2002 17:40
