Go to Post After assisting with the animation last year I realized how cool and useful Inventor was and I started flirting with it. Half a year later I think I have lost all possibility of ever having a girlfriend, and frankly I don't care because I would definately bare the child of this program. - negfrequency [more]
Go Back   Chief Delphi > Technical > Robotics Education and Curriculum
Unread 10-04-2004, 12:46
Software Engineer
VRC #0111 (Wildstang)
Rookie Year: 1995
Re: Using an Operator Interface with the 2004 EDU RC wirelessly
Originally Posted by Astronouth7303
Simple: Dave's method requires special coding (as he says: there is easy way to read what's coming in from the port), not to say we can't get used to it. If the PWMs can be connected correctly, we can bypass that.
Well, now that we know what the real code looks like, it should be easy to redo my code so that it's transparent to the rest of your code. At the time though I didn't know what the real code was going to look like. Unfortunately, I don't have time to do this right now, but maybe someone else could. Basically, I'd just override the Getdata() function that goes and grabs the data from the '03 EDU and returns it in the same struct as the real 04 controller uses. It shouldn't be hard to do this so that the same code will work on either the EDU or the real controller.
Also, the advantage of using this serial method is that you can get the OI digital switches, enabled/disabled bit, etc. as well. If you just use the PWMs, you'd either have to settle for no buttons from the OI or you'd have to make software changes to send the button values over a PWM.
My hints and guess on the Game in 2004! Elgin Clock Rumor Mill 116 09-01-2004 13:30
2004 Championship Eligibility Criteria!!! dez250 General Forum 214 28-12-2003 20:11
2004 will be 2 v 2 Gadget470 Rumor Mill 20 25-10-2003 21:32
2004 Goals Rich Kressly FIRST Interactive Rural SupporT 2 19-10-2003 18:09
2004 OCCRA Competition Gadget470 OCCRA 2 11-06-2003 12:37
