Go to Post According to that logic, Engineers would say there will be twice as many spectators as needed, and we all know that's not the case! - Taylor [more]
Unread 23-03-2002, 21:11
Dan 550's Avatar
Dan 550 Dan 550 is offline
Behold the Awesomeness!
AKA: Dan Richards
#0550 (BattleTech)
Dan 550 is on a distinguished road
Exclamation Warning! Danger!! BAD!!! Radio Cut-Out On-Field!
All hear this: PWM outputs can interfere with the robot's radio signal on a sporadic basis when the standard, low-insulated PWM cables are bound together with wire ties, especially when forming a loop. We all know that that electrical lines cause really nasty radio static in our car radios, but who's really thinking about things like radio interference when you have 20 minutes until the Fed-Ex truck is supposed to pick up your crate and you're still working? Well, to make sure your controller doesn't go into 'No Data/Radio' or even 'Disabled' mode or start behaving erratically, avoid looping PWM cables together and try to seperate your radio and all other cables from each other. Just some help from someone who learned it the hard way at the J&J regional today.
reworking radio control for joysticks ajlapp Electrical 5 05-12-2003 17:38
cut off date? ryan_f General Forum 1 26-10-2003 16:52
How to communicate both through radio and serial port? JC Denton Programming 1 08-02-2003 23:43
radio transmitters Arin Technical Discussion 2 18-12-2002 01:59
radio meetings all star archiver 2001 9 24-06-2002 03:10
