Go to Post I don't know how you can blame a robot getting stuck in the goal on the GDC. The field drawings showed all of the dimensions of the goals. If a team doesn't want to risk getting stuck then they need to plan around it. - JamesBrown [more]
Go Back   Chief Delphi > Competition > Regional Competitions
Unread 23-03-2002, 22:55
K. Skontrianos's Avatar
K. Skontrianos K. Skontrianos is offline
FRC #0102 (Dexterous Gearheads)
K. Skontrianos is an unknown quantity at this point
I also heard about the radio problems at Rutgers. We were fine all day Thursday, but kept cutting out in our first two matches on Friday. (We still won the second match by resetting the robot like crazy and getting a push from our ally.... ) We thought that the radio was the problem but later found out that the light shorted to the frame of the bot. After fixing the wiring, we never cut out again. While your situation sounds a bit different from ours, you might want to double check the wiring before your ship to Florida, if you have time.
Rutgers Regional Website Wayne C. Regional Competitions 7 31-03-2003 18:57
Thanks for the spirit at Rutgers archiver 2001 0 24-06-2002 02:36
Rutgers is Too Crowded archiver 2001 13 24-06-2002 02:28
Improve on Rutgers?!!! Wayne C. Regional Competitions 10 10-04-2002 20:20
Controversy at Rutgers K. Skontrianos General Forum 31 26-03-2002 20:55
