Go to Post Really heavy snow is different in Minnasota and Oklahoma... It has to be pretty bad up there. - thatoneguy23 [more]
Go Back   Chief Delphi > Competition > Rules/Strategy > Scouting
Unread 02-04-2002, 22:54
Bryan Lee Bryan Lee is offline
Bryan Lee is an unknown quantity at this point
Lightbulb
FYI,
I've spent some time in coding up a visual scoring program for the Palm. The app draws the field on the screen and allows you to move pictures of the goals, robots, and tether bot's around the field with a drag of the pen. Tap on the upper half of a goal to add balls and conversely on the lower half to remove balls. A tap on a robot will reveal a little tether bot that can be moved around. Tap on the tether bot to make it go away.
The score is automatically calculated for a best-case/worst-case scoring. To see this in action, place any field element over a zone boundary with the high score in each case highlighted.
Qual points can be computed in place of the raw score.
Also a "trace" capability exists. Check the box and now lines are left behind each object as it's moved around. Handy for explaining strategy to others.
Lastly, the screen can be oriented horizontally or vertically. The latter is better for on-field members of the team.
The latest version is 1.5. I've been uploading it to the white papers section of the forum (I'm sure the 3 revisions I've made in the last 18 hours have been a little taxing on the moderators).
If you/your team ends up using the program and find problems or have suggestions please let me know. There's still time before Florida!
Bryan
[IMG] code is Off
Avantgo for palm... Pin Man Chit-Chat 0 23-04-2003 23:37
HeatWave - Scouting with Palm and Pocket PC BryanJ Scouting 0 12-03-2003 04:41
Team 48's Scouting Database Shelley_delphi chick Scouting 11 28-05-2002 02:14
Palm OS 2002 Robot Database by Team HEATWAVE Paul Dickman Scouting 11 20-04-2002 23:19
Scouting/Scoring System for Palm M3 A. Leese Scouting 12 24-07-2001 23:31
