Go to Post push for what you think is right... just do it in the right way - Andy Baker [more]
Unread 05-04-2002, 00:08
CaptainPlaid's Avatar
CaptainPlaid CaptainPlaid is offline
#0314 (Megatron Oracles "Big MO")
CaptainPlaid is an unknown quantity at this point
We used a very simple design. We are using 4 solid state 12V DC relays for our four drive motors. We connect the power to the relays to the output from the fuse panel to the Victors controlling the motors. When the Victors lose power the relay trips a digital input. We have four LED's on the operator interface to show when the motors are tripped. The base driver also has special glasses with LED's in the side to show them the same thing. That way the driver knows when to let off and the arm driver can hit em if he doesn't slow down. Redundency is good.
I have not failed. I have just found 10,000 ways that won't work.
Thomas Edison
2004 Championship Eligibility Criteria!!! dez250 General Forum 214 28-12-2003 20:11
Championship Qualification - How you would've done it Ken Leung Championship Event 6 26-10-2003 14:00
Wow! what a year archiver 2000 8 23-06-2002 22:43
custom circuit boards ctartist236 Technical Discussion 5 08-01-2002 00:10
Making heads or tails of the new announcement... Jessica Boucher General Forum 66 26-09-2001 11:13
