Go to Post Those chief delphi kids...they think they're so pimp... - Eugenia Gabrielov [more]
Thread Tools Rating: Thread Rating: 7 votes, 4.43 average. Display Modes
Unread 14-12-2004, 23:46
tkwetzel's Avatar
tkwetzel tkwetzel is offline
Good Luck Teams!
AKA: Tyler Wetzel
FRC #0116 (Epsilon Delta)
tkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond repute
Send a message via AIM to tkwetzel
Re: What kind of car do you drive??
Originally Posted by Matt Attallah
2. It's physically impossible for an engine to have "7 Turbos" and keep stock internals. You can run a supercharger or turbocharger (ONE) at around 5-7 psi on a lower-compression engine with premium - but anything more WILL REQUIRE MORE WORK. The most an engine can have is 5 forced inductions. Needs to be in a "V" configuration, and have quad-turbo (Twin turbo on each side of the engine - 4 intakes right there) and one supercharger on top. Anything more will be useless/bog the motor down (and a HUGE waste of money.)
This isn't entirely accurate...you can have 7 turbos, but they would have to be in series which would negate their purpose and would not gain any power for anything past the first one. And you can have more than 4 turbos on a large engine (12+ cylinders) and still have them be efficient. But in general, your knowledge is correct.
3. Every vehicle out there has anti-sway bars. They are called "Sway Bars" and help to stop the roll of the body. If you off-road you disconnect these so you can get better 'flex' out of your suspension.
In general this is correct, but there are a few (maybe only a couple) of cars out there without sway bars. Sorry I can't hink of any of them right now, but if I remember them I will get back to you.
Originally Posted by Mini-D67
Just going by what the site said... I'd assume that the crank and a few other rotating parts were swapped, maybe they meant the same pistons/rings and whatnot?
The pistons and connecting rods are usually the weakest parts in the engine when it comes to forced induction. Forged pistons and rods are needed for a car running high boost.
See you in DC!
1 stick drive to 2 stick drive wayne 05 Programming 18 01-04-2004 16:41
how does crab drive work? Soukup Technical Discussion 13 25-04-2003 11:31
Direct drive or Chain? Suneet Technical Discussion 32 27-03-2003 23:00
What kind of car do you drive? Amber H. Chit-Chat 49 03-10-2002 21:20
