Re: Kevin Watson's Kick-off Demo Code!
No, the sensor that's included in the kit is the accelerometer, it's similar but it's not the same thing.
The accelerometer gives you the instant acceleration, and the gyro gives you the angular velocity. |
| Coding / Style Standards for sharing C code | Joe Johnson | Programming | 33 | 01-05-2004 15:15 |
| heres the code. y this not working | omega | Programming | 16 | 31-03-2004 15:18 |
| Conflict between "Initialize_Tracker()" and "pwm13 & pwm15"? Kevin? | gnormhurst | Programming | 3 | 22-02-2004 02:55 |
| EDU Demo Code: Encoder Interfacing Using Interrupts | Kevin Watson | Programming | 4 | 08-01-2004 23:14 |
| EDU Demo Code: Serial Data Transmitter Using a State-Machine | Kevin Watson | Programming | 3 | 28-12-2003 22:56 |
