Go to Post Brandon, can you make some sort of mind-reading device that i can just think "portal" and i'll go back? - Tom Schindler [more]
Go Back   Chief Delphi > Competition > Championship Event
Unread 19-04-2002, 21:23
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Zone Zeal Pool
ZoneZealPool Entry Form (alternate download)
Hi all,
In order to steal another page from what works in sports, I have hit upon the idea of trying to generate some added excitement about the FIRST Championships by starting a Zone Zeal Pool (ala the very popular NCAA Men's Basketball Tournament pools).
Here is how it is going to work:
You make your favorite picks for the tournament.
You submit those picks to us via an Excel spreadsheet mailed to ZoneZealPool@ChiefDelphi.com
Prior to the tournament, as entries come in, we post information about which teams are being handicapped to go how far.
During and after the Elimination Rounds, we will post the scores and usernames of the higher scoring entries.
After the Championships, we will post the winning entry (so you can all see how that high score was obtained) and to make things interesting, I, personally, will give a $100 gift certificate from Home Depot to the winner.
More rules about who can enter and other details are included in the Excel file and below.
Good Luck.
Joe J.
1) Choose the 16 teams from each division that will you believe will be most likely to be in the Divisional Quarter-Finals of the Elimation Tournament
2) From the above list, choose 8 per division that you believe will most likely pass on to the Divisional Semi-Finals
3) From the above list, choose 4 per division that you believe will most likely pass on to the Divisional Finals
4) From the above list, choose 2 per division that you believe will most likely pass be the Divisional Champions
5) From the above list of 4 pairs of Divisonal Champions, pick the 2 pairs that you believe will be most likely to pass on to the Grand Finals
6) From the above list of 2 pairs of Grand Finalist, pick the 1 pair that you believe will be most likely to pass on to the Grand Finals
7) Enter X's in the appropriate boxes on the DATA ENTRY sheet. NOTE: "ERRORS" MUST BE ZERO (0) FOR YOUR ENTRY TO BE CONSIDERED!
8) "Save As" Replacing "YOURNAMEHERE" with your ChiefDelphi.com username
9) E-mail the entry with the file attached to: ZoneZealPool@ChiefDelphi.com
10) Entries must be received before 9:00am EDT Friday April 26, 2002 to be considered
11) The pool is just for fun, but, Dr. Joe has decide to make things interesting by providing a $100 gift certificate from Home Depot to the person who submits the entry with the highest score.
12) In order to be eligible for the gift from Dr. Joe, you must meet the following criteria:
You must submit only one entry per person
You must be a registered member of the ChiefDelphi.com Forum
You must submit a 100-300 word response to the message titled: Zone Zeal Pool "Entry Fee"
13) Members of the Chief Delphi team are welcome to submit entries, but will not be eligible for the gift from Dr. Joe.
14) With the exception of the winning pool entry, no individual pool entries will be made public. Other than the winning name and winning pool entry, only the names and SCORES (as opposed to pool entries) will be published.
15) Information about team's scores (see team scoring below) will be made public on the ChiefDelphi.com web site
16) Scores for individual pools will be calculated as follows:
1 point for each correct divisional quarter-finalist
2 points for each correct divisional semi-finalist
4 points for each correct divisional finalist
8 points for each correct divisional champion
16 points for each correct grand finalist
32 points for each correct grand champion
17) Scores for Teams will be posted on the ChiefDelphi.com website. Teams will get points for each pool entry similar to the manner that pool entries are scored (the numbers will be normalized by the number of pool entries).
1 point for each pool entry predicting that the team will be a divisional quarter-finalist
2 points for each pool entry predicting that the team will be a divisional semi-finalist
4 points for each pool entry predicting that the team will be a divisional finalist
8 points for each pool entry predicting that the team will be a divisional champion
16 points for each pool entry predicting that the team will be a grand finalist
32 points for each pool entry predicting that the team will be a grand champion
18) As usual, the decisions of the judge (Dr. Joe) is final and not necessarily fair and/or just. Sorry in advance.
Unread 19-04-2002, 21:30
AKA: Dr. Joe
FRC #0088 (TJ2)
Link to Entry Form / Spread Sheet
The entry form is in the whitepapers section of this website.
The link above should download it for you.
Joe J.
Unread 19-04-2002, 22:00
Joel J's Avatar
Joel J Joel J is offline
do you..
What should the 100-300 word response contain? I can't figure it out.
Joel Johnson
RAGE (173) Alumni, 1999-2003
Unread 19-04-2002, 22:07
AKA: Dr. Joe
FRC #0088 (TJ2)
More Info on "Entry Fee"
Go to this message to find out more on the "Entry Fee"
Unread 20-04-2002, 08:04
AKA: Dr. Joe
FRC #0088 (TJ2)
Questions of general interest:
About the pool...
What exactly is this data entry sheet that you refer to? I realize there's an entry form, but there just seems to be guidelines on it, not places to enter in data. Would you like us to write to the right of all the cells, or should I make my own spreadsheet and submit it to you?
How would you like the 100-300 page essay submitted to you? Should that be attached with the spreadsheet as well?
DO NOT WRITE YOUR OWN SPREADSHEET! The format of the data is important because we are going automate the pool scoring process and we need you to leave the file just as is, only putting X's in the proper boxes.
As to where to enter data, in Excel, there are sheet tabs at the bottom of the page that let you switch to different sheets of the spreadsheet. In the pool entry spreadsheet, there are 2 sheets. There is one called "Instructions" which is the one you see when you open the spreadsheet. There is another called "DATA ENTRY" Click on the tab and you will be ready to enter you pool choices.
As to how to submit the essay, just reply to the thread on the forum.
Joe J.
Unread 20-04-2002, 13:03
Ricky Q.'s Avatar Unsung FIRST Hero
Ricky Q. Ricky Q. is offline
yee haw!
FRC #0148 (Robowranglers)
Ricky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond repute
Send a message via AIM to Ricky Q.
Bad E-mail.....
I just tried to send in my entry, and it got returned saying;
zonezealpool@comcast.net
(ultimately generated from ZoneZealPool@chiefdelphi.com)
SMTP error from remote mailer after RCPT TO:<zonezealpool@comcast.net>:
host mx00.comcast.net [24.153.64.1]: 550 5.1.1 unknown or illegal alias:
Let me know when its fixed...
Ricky Quinones
Director of Sales - VEX Robotics
Unread 20-04-2002, 13:20
AKA: Dr. Joe
FRC #0088 (TJ2)
Sorry about that... working on it...
The team member from our team that was supposed to set up the mailbox to recieve the entries must have gotten too busy last night to get it set up.
Hold off sending it until I get the all clear signal.
Sorry for the delay.
Joe J.
Unread 20-04-2002, 13:57
purplehaze357's Avatar
purplehaze357 purplehaze357 is offline
OMG We're Back Again
AKA: Joe Troy Jr.
#0357 (Royal Assault)
purplehaze357 is on a distinguished road
Send a message via AIM to purplehaze357 Send a message via Yahoo to purplehaze357
what about us mac users?
2004 Philadelphia Regional Referee
2005 Pittsburg Regional Referee
2005 Philadelphia Regional Referee
2003 Chesapeake Regional Chairmans Award Winners
2003 Chesapeake Regional "Delphi Driving Tormorrows Technology" Recipients
Aim: smallmanjoe98
Email: jtroy@temple.edu
Unread 20-04-2002, 14:20
AKA: Dr. Joe
FRC #0088 (TJ2)
Mac users have many issues...
I am sorry, but I just can't help you Mac folks ;-)
Basically, we need the spreadsheet filled out and mailed in. Can you visit the library or a friends in order to fill it out?
Wish I could do more.
Anybody have any better help for Mac users?
Joe J.
Unread 20-04-2002, 16:06
Dima Dima is offline
Dima is just really niceDima is just really niceDima is just really niceDima is just really niceDima is just really nice
Send a message via AIM to Dima
Now that we are on ths theme again
I heard form some people that you favorite drink did in fact change so would you still like 5 cases of mountain dew or something else?
Unread 20-04-2002, 16:43
AKA: Joe Troy Jr.
*tear tear*....that hurts joe...
No im just kidding...ill go to a friends and fill it out..thanx
Aim: smallmanjoe98
Unread 20-04-2002, 17:12
FRC Key Volunteer Trainer
AKA: CrazyNate
Re: Mac users have many issues...
The Mac versions of Excel(and all of the Office apps, for that matter) create files 100% compatible with their Windows counterparts. Even though Excel probably won't list the file on a Mac when you go to open it, if you select All Files from the list of file types to show, it should show up and open without a problem.
Nate Smith
nsmith@smythsoft.com
Unread 20-04-2002, 18:01
AKA: Joe Troy Jr.
i am fully aware of this....that is if the file that you are downloading doesnt crash IE....it doesnt want to d/l it....
Aim: smallmanjoe98
Unread 20-04-2002, 18:13
Brandon Martus's Avatar Unsung FIRST Hero
Brandon Martus Brandon Martus is offline
busy.
AKA: B. Slash Kamen
Brandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond repute
Send a message via ICQ to Brandon Martus Send a message via AIM to Brandon Martus Send a message via Yahoo to Brandon Martus
NEW VERSION!
There is a new version of the file uploaded ... 1.2
Make sure you are filling it out.
Brandon Martus
e-mail
Unread 20-04-2002, 18:23
AKA: Joe Troy Jr.
mac compatible !!??
Aim: smallmanjoe98
Zone Zeal Game Simulator RBrandy General Forum 2 18-06-2002 23:38
Zone Zeal Pool "Entry Fee" Joe Johnson Championship Event 21 26-04-2002 02:56
The object of Zone Zeal???? Jay5780 General Forum 15 09-04-2002 19:54
Zone Zeal logo David Kelly General Forum 2 28-03-2002 18:52
Zone Zeal ready for prime time? Joe Johnson Regional Competitions 15 12-03-2002 09:36
