Go to Post I blame FIRST for being the best thing that has happened to me. - vivek16 [more]
Unread 12-01-2005, 13:35
Squall Squall is offline
Squall is an unknown quantity at this point
Re: Kevin Watson's Kick-off Demo Code!
Originally Posted by Mark McLeod
Post the model gyro you are using and we might be able to help with those parameters.
Hi, We're using this one :
ADXRS150 from analog devices
It's datasheet can be found here :
http://www.analog.com/UploadedFiles/...ADXRS150_B.pdf
We kind of understand the values that we have in the datasheet, but we really couldn't find one that could match the ones needed to alter in Kevin's code.
Thanks for your attention
Girafales - TEAM #1382
Coding / Style Standards for sharing C code Joe Johnson Programming 33 01-05-2004 15:15
Conflict between "Initialize_Tracker()" and "pwm13 & pwm15"? Kevin? gnormhurst Programming 3 22-02-2004 02:55
EDU Demo Code: Encoder Interfacing Using Interrupts Kevin Watson Programming 4 08-01-2004 23:14
EDU Demo Code: Serial Data Transmitter Using a State-Machine Kevin Watson Programming 3 28-12-2003 22:56
