Go to Post why re-invent the wheel when it still rolls? just make it better. - Tytus Gerrish [more]
Unread 22-01-2005, 17:39
Code\\Pilot Code\\Pilot is offline
< Only smart people see my avatar
AKA: Rafael Estrada
FRC #1065 (Tatsu)
Code\\Pilot is an unknown quantity at this point
Send a message via AIM to Code\\Pilot Send a message via MSN to Code\\Pilot
Camera not found!!!
So, first i plugged the camera to some power, than to the serial port on the computer. I run the GUI and it works awesome, still cant calibrate it because i dont have the paint yet. So the camera works...BUT when I plug the camera to the robot controller and turn on the bot, the print window from the ifi loader says: Camera not found, check power cable and ttl connection, but the power is on and the camera connected!! Could it be cause i havent calibrated the cam yet? Any help will be humongesly appreciated.
Join the Red revolution, give me some RED rep!!!!
if it doesn't work, don't force it. Go get a bigger hammer.
int run = 0;
int robot_chasing_you = 1;
if (robot_chasing_you)
run = 254;
I got 48 Gmail invites left, pm me with your e-mail so i can send you one.
Unread 22-01-2005, 17:58
Greg Marra Greg Marra is offline
[automate(a) for a in tasks_to_do]
FRC #5507 (Robotic Eagles)
Greg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond repute
Re: Camera not found!!!
Are you sure you have the TTL serial link to the RC controller connected properly? We got this error today and realized we didn't have the camera connected to the RC board.
Unread 22-01-2005, 18:54
Damian Manda's Avatar
Damian Manda Damian Manda is offline
The Damian
Damian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud of
Send a message via AIM to Damian Manda
Also, as stated in other threads, make sure the camera is also not plugged into the windows GUI at the same time
FRC Volunteer, FLL regional planning committee member for Colorado
Former Programmer, Web Designer, Communications Director of Alpine Robotics Team 159.
Add your team to the FIRST Teams Google Map
Unread 24-01-2005, 16:33
AKA: Rafael Estrada
FRC #1065 (Tatsu)
Ok, the camera is not plugged to the GUI, the power is plugged to a pwm, the ttl control chip connected to the camera board and plugged to the robot controller in their correspondidng connections. Dowloaded the the default code provided by first with camera support. I can see the camera has power, i have tested the camera with my computer, but still the ifi terminal window tells me that the camera is not found. I am very afraid that the serial chip might be broken . Any help will be GREATLY appreciated.
Thanks.
int run = 0;
run = 254;
Unread 24-01-2005, 16:37
Bharat Nain's Avatar
Thanks.
You cannot have the TTL port and the RSS port conected to the camera at the same time. Connect the pwm to the camera and the RSS to the computer. Disconnect the TTL port and then try.
-= Bharat Nain =-
Whatever you do, you need courage. Whatever course you decide upon, there is always someone to tell you that you are wrong. There are always difficulties arising that tempt you to believe your critics are right. To map out a course of action and follow it to an end requires some of the same courage that a soldier needs. Peace has its victories, but it takes brave men and women to win them. - Ralph Waldo Emerson
Unread 24-01-2005, 16:50
AKA: Rafael Estrada
FRC #1065 (Tatsu)
Already tried that, not working. My camera is Not connected to the PC, is only connected to the robot.
int run = 0;
run = 254;
Unread 27-01-2005, 19:52
kjohnson's Avatar
kjohnson kjohnson is offline
Insert Clever Title Here
AKA: Kyle J.
FRC #1610 (BOT)
kjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond repute
we are having the problem of "camera not found" again. Several days ago we had fought through this error code and were successful in overcoming it. We have tried new wires, manual suggested power downs, charged battery packs. The code indicates that the camera_reset()==0 in the user_camera.c code is the point the program is getting hung up on, however when we printed that value, it indicated it was 6204.
The camera itself works fine, we can calibrate, grab images, automatically track colors when the computer is hooked up to the camera itself. The RC will not recognize that the camera is there and powered up.
Any suggestions prior to us attempting to get a new TTL adapter would be appreciated.
Thanks for your help.
Unread 27-01-2005, 19:59
AKA: Rafael Estrada
FRC #1065 (Tatsu)
I have a new problem now, not even the GUI will recognize the camera. The console displays the message: Looking for camera... and doesn't move from there. It used to work before.
int run = 0;
run = 254;
Unread 28-01-2005, 15:31
kjohnson's Avatar
AKA: Kyle J.
FRC #1610 (BOT)
Has anyone been able to figure this problem out yet? I have tried everything again today and it is still not working. Any other suggestions?
Unread 31-01-2005, 16:19
AKA: Rafael Estrada
FRC #1065 (Tatsu)
I took my cam to another team's place, they had their camera working so they tried our camera, apparently our camera is fryed or cracked :'(
int run = 0;
run = 254;
Unread 31-01-2005, 16:22
kjohnson's Avatar
AKA: Kyle J.
FRC #1610 (BOT)
We also went to another team for help. It turned out our camera was fine but our TTL/RS-232 converter was bad.
Unread 02-02-2005, 00:04
Joshua Lynn Joshua Lynn is offline
FRC #0423 (SEC Mechanical Mayhem)
Joshua Lynn is on a distinguished road
Added some infromation on this issue in another thread
Found Here
Scripting Setup and the Camera + Serial Port Drivers CJO Programming 22 11-01-2006 17:42
WARNING- New camera meets magic smoke anna~marie Kit & Additional Hardware 20 01-02-2005 12:37
Kevin Watson's Kick-off Demo Code! Mr. Lim Programming 27 22-01-2005 03:38
Game Field Camera Calibration Matthew_H Regional Competitions 2 15-01-2005 23:09
CMUCam2 Camera Code - Are important parts commented out? Mr. Lim Programming 4 14-01-2005 12:11
