Go to Post The toughest regional that matters is the one you're in! - pfreivald [more]
Unread 07-10-2003, 12:08
CD47-Bot CD47-Bot is offline
FRC #0047 (Chief Delphi)
CD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond repute
pic: 2 speed shifty on the fly Lego Bot
SpaceOsc's Avatar
SpaceOsc SpaceOsc is offline
16 Years of FIRST!
AKA: Oscar Vasquez
FRC #4501 (Humans)
SpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant future
Send a message via AIM to SpaceOsc Send a message via Yahoo to SpaceOsc
Thumbs up Lego Bot
Most impressive
2014-2017: Team 4501 Coach/Lead Mentor
2002-2011: Team 702, Mentor
2001-2002: Team 702 Captain
Unread 07-10-2003, 16:23
rlowerr_1's Avatar
rlowerr_1 rlowerr_1 is offline
#0930 (M³)
rlowerr_1 is an unknown quantity at this point
Send a message via AIM to rlowerr_1
Although this is cool I really don’t see the advantage of it for the Lego League competition. Wouldn’t the motor used for the shifter be better used for some sort of special function? When does the robot really need to have any pushing power?
Ryan Lowerr - Ryan@lowerr.com
Check out my LEGO creations here!
Unread 07-10-2003, 17:12
Ryan Dognaux's Avatar
Ryan Dognaux Ryan Dognaux is offline
Back Home in Indiana
FRC #4329 (Lutheran Roboteers)
Ryan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond repute
Send a message via AIM to Ryan Dognaux
I'd like to see some video of this in action!!
Ryan Dognaux :: Last Name Pronounced 'Doane Yo'
Team 234 Alum: 2002 - 2005 :: Purdue FIRST Member: 2006 - 2009
Team 1646 Mentor: 2007 - 2009 :: Team 357 Mentor: 2009 - 2012
Team 4329 Mentor: Current
STL Off-Season Event: www.gatewayroboticschallenge.com
Unread 07-10-2003, 23:37
Tytus Gerrish's Avatar
Tytus Gerrish Tytus Gerrish is offline
IGAB, ADHD, and Dislexic
AKA: Ty
FRC #0179 (SwampThing)
Team Role: Tactician
Tytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond repute
i can take video with my digital camera no sound tho
BTY:What do i need to digitise my stuff from my videocamera?
Unread 09-10-2003, 17:34
Frank(Aflak)'s Avatar
Frank(Aflak) Frank(Aflak) is offline
#1067 (SLUH)
Frank(Aflak) is on a distinguished road
very clever, tytus. Its amazing what legos are capable of, huh? My favorite is a copy machine . . I built three or four of those, with varying degrees of success.
I like using a worm-gear to shift. A very cool design.
Unread 01-12-2004, 21:54
SoftwareBug2.0's Avatar
AKA: Eric
FRC #1425 (Error Code Xero)
Re: pic: 2 speed shifty on the fly Lego Bot
If you have an analog video camera, you would need a video capture card. Pinacle is a big maker of these. To use is you would just plug the output of the camera that could go into a TV or VCR into the capture card, tell it to start recording on your computer, and tell the camera to roll the film. You can get a standard capture card for under $100.
Unread 02-12-2004, 21:33
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
That's nifty, Tytus. I built something similar this summer, and then drew it up in MLCad. I don't have any of the Lego pnuematics, so I did it all with motors, which was an interesting challenge in itself. The left wedge wheel is the output, and the right goes to the shifting motor.
For anyone interested:
4 Brick 1 x 16
3 Brick 2 x 4
1 Electric Technic Mini-Motor 9v
2 Plate 1 x 2
3 Plate 2 x 4
6 Technic Axle 4
2 Technic Axle 8
1 Technic Axle 10
1 Technic Axle Joiner
2 Technic Brick 1 x 16 with Holes
15 Technic Bush
6 Technic Bush 1/2 Smooth
6 Technic Gear 8 Tooth
1 Technic Gear 24 Tooth Crown
4 Technic Gear 40 Tooth
2 Technic Gear Rack 1 x 4
1 Technic Plate 1 x 4 with Holes
2 Technic Wedge Belt Wheel
1 Technic Worm Screw
It's huge and unwieldy, but it works, and it's kinda cool.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 23-12-2004, 12:01
Tim Delles's Avatar
Tim Delles Tim Delles is offline
Since 2001.
FRC #0078
Tim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond repute
very impressive.. i've tried for a while to make a good shifter for a lego bot but i could never get it to shift on the fly.. i even tried to use pneumatics and that wasn't the best either. good job.
Timothy Delles - Clarkson University
2011 - Present: FRC Team 78 - AIR Strike
2011 - Present: VEX Team 78 - AIR Strike
2010 - 2011: FRC Team 3280 - Rhode Rebels
2001 - 2009: FRC Team 229 - Division By Zero
Unread 31-01-2005, 04:21
elknise's Avatar
elknise elknise is offline
AKA: Erik Knise
FRC #1318 (Issaquah Robotics)
elknise will become famous soon enoughelknise will become famous soon enough
That looks cool. Did you do it to help with a lego bot or did you do it just for fun and to say you did. That is sweet though and looks really cool.
Elknise
Issaquah Robotics
pic: Tytus Crab Drive lego model CD47-Bot Extra Discussion 11 08-09-2003 18:36
pic: Diff lego experment CD47-Bot Extra Discussion 12 08-09-2003 13:44
pic: lego Planitary... Kinda CD47-Bot Extra Discussion 5 14-07-2003 23:55
pic: 3-speed lego geerbox CD47-Bot Extra Discussion 4 14-07-2003 23:42
Shift on the fly LEGO gearbox rlowerr_1 Robot Showcase 17 14-07-2003 23:33
