Go to Post You need a good BAD (*BAD = Ball Acquisition Device) - DonRotolo [more]
Unread 04-02-2005, 08:01
capenga's Avatar
capenga capenga is offline
Penga boy
AKA: Giovane
#1156 (Under Control)
capenga is an unknown quantity at this point
Send a message via ICQ to capenga Send a message via MSN to capenga
Exclamation Re: Unresponsive camera
We're having the same problem as you...
but following the procedures of the document .pdf for testing the TTL 232, we evidenced that the TTL port and the TTL 232 don't have any problem. But, when we reloaded the default code 2.4, the camera continues to not be found. Maybe the problem is not the TTL
We're really confused right here
Ignore alien orders.
Unread 04-02-2005, 09:28
Joshua Lynn Joshua Lynn is offline
FRC #0423 (SEC Mechanical Mayhem)
Joshua Lynn is on a distinguished road
We have conducted the prescribed test as well and found that the TTL-232 board was working.
Yet we continued to find that we had the camera not found problem.
We also discovered a few other things:
The trigger on the joystick attached to port 2 was not functioning. This explains why on occasion it would NOT give us the “camera not found error” but the lights on the OI to indicate which color to track would not change.
Currently, the camera is working with the robot on the bench in the workshop area.
However, I still don’t know why it is working.
When we started testing on the bench it was NOT working.
We retested every thing again including the TTL-232 board. All ok, still it didn’t work.
Then it did work.
The current hypothesis is that it is a problem in the connectivity. Each end is just fine but the connection is tenuous in between. It could be a loose connection or it could be RF interference with the power system based on the routing of the signal wire to the power distribution system.
It is frustrating because its working and I don’t know why!
Unread 17-02-2005, 08:51
capenga's Avatar
Penga boy
AKA: Giovane
INCREDIBLE!!!
Here, in a desperated act, we turned the camera on the 2004 RC (It haves a TTL port), by updating the firmware and downloading the 2.4 code. It works.
So we tried to do everything by the beginning with the 2005 RC, downloading the 2.4 code clean on the IFI webpage, updating the firmware again, and then.... TADA!! THE CAMERA NOW IS WORKING!! Our team is very happy now.
I think that do everything by the beginning can help the teams with this problem.
Scripting Setup and the Camera + Serial Port Drivers CJO Programming 22 11-01-2006 17:42
Camera not found!!! Code\\Pilot Programming 11 02-02-2005 00:04
Kevin Watson's Kick-off Demo Code! Mr. Lim Programming 27 22-01-2005 03:38
Game Field Camera Calibration Matthew_H Regional Competitions 2 15-01-2005 23:09
CMUCam2 Camera Code - Are important parts commented out? Mr. Lim Programming 4 14-01-2005 12:11
