Go to Post i have a feeling that the field with be the same as it was last year just to save some money. but what is inside the the field will be diferent. - Michael Leicht [more]
Unread 05-02-2005, 13:57
schenkin schenkin is offline
schenkin is on a distinguished road
Re: Autonomous With Camera
Ok, I think what i'm going to do is just make the function within Default_Routine() a function outside of the loop and then call on it within it. Then I can run that code from user_routines_fast(). Color selection will be accomplished by mimicking joystick button presses.
Not the most elegant, but it might work.
--Sam
--Team 486: Positronic Panthers
Scripting Setup and the Camera + Serial Port Drivers CJO Programming 22 11-01-2006 17:42
Unresponsive camera neilsonster Programming 9 17-02-2005 08:51
CMUCam2 Camera Code - Are important parts commented out? Mr. Lim Programming 4 14-01-2005 12:11
autonomous mode problem on field Chris_C Programming 17 26-03-2003 19:11
