Go to Post So in the words of one Leroy Jenkins, "Time's up, let's do this." - Frenchie461 [more]
Unread 13-02-2005, 04:20
russell's Avatar
russell russell is offline
#1430 (WRONG)
Team Role: Electrical
russell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to all
Re: Autonomous With Camera
I assume you mean you want to be able to track red, or blue depending on which team you are on? Hmmm. Is there some way your program can know which team you are on? If not then use a switch you can set for which team you are on, then when you are running those functions at the beginning have it say camera_find_color(thecolor); and earlier in the program have an if/then to make it set thecolor equal to red or blue (there are some numbers that represent the different colors... I think 4 and 5 respectively, but you might want to check that) based on the position of your switch. It is again, crude but it works.
If I were you though I would not use that code I posted above for your final program, I really only meant it as a model of what you can do, you will probably want to elaborate on it.
Scripting Setup and the Camera + Serial Port Drivers CJO Programming 22 11-01-2006 17:42
Unresponsive camera neilsonster Programming 9 17-02-2005 08:51
CMUCam2 Camera Code - Are important parts commented out? Mr. Lim Programming 4 14-01-2005 12:11
autonomous mode problem on field Chris_C Programming 17 26-03-2003 19:11
