Go to Post I can tell you for a fact that students don't need smartphones in order to unproductively entertain themselves in a robotics lab. - remulasce [more]
  #32   Spotlight this post!
Unread 01-05-2002, 15:51
Matt_Gray Matt_Gray is offline
#0226 (TEC CREW)
Matt_Gray is an unknown quantity at this point
Send a message via AIM to Matt_Gray Send a message via Yahoo to Matt_Gray
C++ serial input
Hey... does anyone know how to write a segment in C++ (if it helps I use the Bourland compiler) to input information from the dashboard output to a communitcations port on the back
How to communicate both through radio and serial port? JC Denton Programming 1 08-02-2003 23:43
Problem with communicating with STAMP through serial port Skabana159 Technical Discussion 2 06-02-2003 21:10
Ever seen this serial port problem before??? Aidan F. Browne Programming 5 05-02-2003 12:03
organized way of communication with FIRST? archiver 2001 0 24-06-2002 04:20
Serial Port Communication White Paper rbayer Programming 87 14-06-2002 16:10
