Go to Post Is it really that bad to ask a team to be able to do more than just drive? It's like asking a student to do more than just show up to class... - Katie_UPS [more]
Unread 02-05-2002, 13:11
soap108's Avatar
soap108 soap108 is offline
FRC #0108 (SigmaC@T)
Rookie Year: 1995
soap108 is a splendid one to beholdsoap108 is a splendid one to beholdsoap108 is a splendid one to beholdsoap108 is a splendid one to beholdsoap108 is a splendid one to beholdsoap108 is a splendid one to beholdsoap108 is a splendid one to behold
Re: would have loved to use it but
Originally posted by Alfred Thompson
Every time I cam by to ask for the connect info I was told to hook into an open ethernet wire. I would have prefered to use the wireless NIC (I always travel with both).
Two suggestions: One try and get someone to mount an access point high up. Or better yet, two access points in different parts of the tent so that range is improved.
Two, print up a handout with the lan settings required for connection. That will save time.
Yeah, I pointed you to the wired LAN since I knew 100% that it would work with no hassle. I'm surprised as many people had a good time on the 80211 since we didn't have a well thought out requirements, design, and implementation plan in place. We kinda made things up as we went.....
There were several access points (at least 3 that I know of) that had the soap_wireless SSID throughout the Pit. There may have been one or two near Curie..... Joel- where'd you put them?
Yes, bandwidth is shared...more or less.... 11Mbps max in theory 3-4Mbps in reality.
There were enough higher priority issues with the scoring system that the widget that updates SOAP wasn't monitored the way it was at Chicago.
We will work much closer with the production companies to get the WAPS higher up. Thanks for the idea.
Adding IM or chat or something would not be too hard, but I'd rather see people "talk" IRL.....
KA-108
Q&A Discuss: wireless camera CD47-Bot Extra Discussion 3 16-01-2003 18:09
Did you use the 802.11b wireless LAN at EPC@T? soap108 Championship Event 21 04-01-2003 11:03
Pit network for scouting archiver 2000 13 23-06-2002 22:51
Proposal for a LAN at the National Competition archiver 2000 6 23-06-2002 22:18
LAN party, anyone? FotoPlasma Chit-Chat 31 14-02-2002 12:59
