Go to Post The only people who are dumb or ignorant in this world are the ones who don't stop and ask why. - T967 [more]
Unread 04-06-2002, 21:26
rbayer rbayer is offline
Blood, Sweat, and Code
no team (Teamless Orphan)
Despite what it may seem like, you still do need multithreading. Without it, there will be no way to quit the serial capture program. Although, if it is a console app, you should still be able to ctrl+C it. It may lead to some minor memory leaks, but no big deal.
Anyway, the way you are describing doing this is fairly simple. In the SerialThread function, where I said to do the data processing, just sort through the twenty-six bytes it reads in, looking for the begining. Once it finds the begining of a packet, start writing out each byte to a file. You can even do this while inside the SerialThread function.
BTW, what compiler will you be using?
Win32 serial port - recieve buffer seanwitte Programming 4 05-11-2003 21:41
White Paper Discuss: FIRST Editor v1.2 CD47-Bot Extra Discussion 1 18-09-2003 19:32
How to communicate both through radio and serial port? JC Denton Programming 1 08-02-2003 23:43
Ever seen this serial port problem before??? Aidan F. Browne Programming 5 05-02-2003 12:03
serial communication using c++ Malakili Programming 31 01-05-2002 15:51
