Go to Post What is this "tired" of which you speak? Did it come in the KOP? - EricH [more]
Unread 05-06-2002, 11:49
Software Engineer
VRC #0111 (Wildstang)
Rookie Year: 1995
How about this: it is the best supported windows compiler out there. As soon as gcc gets all the point and click UI stuff that VC++ has, I will switch in a second.
I thought you were talking about the compiler itself being the best compiler, which I have problems with because the Visual C++ compiler has issues with standards compliance. As for the GUI, there are several nice ones that work on top of GCC. GCC itself is just a compiler, just like the command line compiler that's part of VC++. Personally, one of the biggest benefits for me with GCC or other compilers is that I don't have to use the bloated user interface. I greatly prefer the ease of use and flexibility of a good editor (nedit) and Makefiles coupled with a command line, but that's just me.
With the way windows does handles, it is still possible to have resources allocated after a program quits.
If this is true then that sounds like (yet another) Windows bug. (I can't say that I know much about Windows GUI programming; I try to avoid Windows as much as possible.) A true OS would never allow a user process to allocate memory that can never be recovered, no matter how the application is terminated.
Win32 serial port - recieve buffer seanwitte Programming 4 05-11-2003 21:41
White Paper Discuss: FIRST Editor v1.2 CD47-Bot Extra Discussion 1 18-09-2003 19:32
How to communicate both through radio and serial port? JC Denton Programming 1 08-02-2003 23:43
Ever seen this serial port problem before??? Aidan F. Browne Programming 5 05-02-2003 12:03
serial communication using c++ Malakili Programming 31 01-05-2002 15:51
