Go to Post I'm somewhat fond of saying, if your robot dosen't weigh 119.99 pounds, you forgot something. - Francis-134 [more]
Go Back   Chief Delphi > FIRST > Rumor Mill
Unread 22-11-2005, 15:59
sciguy125 sciguy125 is offline
Electrical Engineer
AKA: Phil Baltar
FRC #1351
sciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond repute
Send a message via AIM to sciguy125 Send a message via MSN to sciguy125 Send a message via Yahoo to sciguy125
Re: 2006 game hints?
Originally Posted by sciguy125
Divide that by the sum of the sides of on the scoring objects and the field...
I need to amend that to read:
"Divide that by the sum of the sides on the planar projection of the scoring objects and the field. i.e. a tetra is 3 sides, a box is 4 sides..."
Many have speculated a baton. However, per my theory, that would require a 5 or 6 sided field.
Assuming a traditional rectangular field, the scoring object would need 3, 5, 8, or 13 sides.
Assuming a hexagonal field, as apparently has been used in the past, the scoring objects would need 1, 3, 6, or 11 sides.
My prediction: for the last several years, the final number has not just been a multiple of 4, it has been a multiple of 12. That leaves us with the rectangular field and 8 sided object or hexagonal field and 6 sided object. Because of the complexity involved with building an 8 sided scoring object, I'm going with the hexagonal field with 6 sided object.
-----BEGIN GEEK CODE BLOCK-----
Version: 3.12
GE/S/P a-- e y-- r-- s:++ d+ h! X+++
t++ C+ P+ L++ E W++ w M-- V? PS+ PE+
5- R-- tv+ b+ DI+++ D- G
------END GEEK CODE BLOCK------
Unread 22-11-2005, 16:13
pyroslev's Avatar
pyroslev pyroslev is offline
VirginiaFIRST FTA
AKA: Jack of all trades, Master of few
no team (Forget not 616)
pyroslev is on a distinguished road
Patterns. I would almost bet money on the game resembling one of the past four years (Zone, Stack, Raise and Triple) in a major way. I would also count on there being a twist that will make jaws drop (It's dave's nature!).
Add in the fact that we are due for a game of boxes or balls.
2001 Balls and goals with ramp
2002 Balls with goals in zones
2003 Boxes and ramp
2004 Balls with platform, bar and goals
2005 Tetras and goals
It's a cycle. SOmething tells me boxes but not like were expecting.
Unread 22-11-2005, 17:11
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
That sounds like something from Numb3rs.
A six-sided object would be a cube or a rectuangular prism. This would not figure into the pattern of the recent FIRST games, in which even-numbered years use an odd-number-sided playing field object. This all seems pretty interesting that these patterns have been discovered, even though they may be very weird coincidences. What would the odds be that FIRST is actually following a set algorithim for determining their games each year? I'm guessing maybe infinity minus one to one against. Only in 45 days on January 7th will we really know.
Art Dutra IV
世上无难事,只怕有心人.
Unread 22-11-2005, 17:35
Andrew Blair's Avatar
FRC #0306 (CRT)
The only real thing you can rely on in the games is the need for a good, solid drivetrain, and a good lift or equivalent device. Every year, there has been carpet (sorry water people), and there has been something needing to be put somewhere higher. Maybe FIRST will repeal that "no throwing game objects" rule this year!
-Sir Francis Bacon
-Albert Einstein
Unread 22-11-2005, 18:58
JoelP JoelP is offline
whats the P for? Pazhayampallil
FRC #1155 (Bronx Science Sciborgs)
JoelP is a jewel in the roughJoelP is a jewel in the roughJoelP is a jewel in the rough
Send a message via AIM to JoelP
Maybe they'll have us use the camera, infrared, or some sonar device to find the distance to a target and we'll have to program ballistics calculations to shoot the game object into the goal...catapults anyone?
Unread 22-11-2005, 20:44
Electrical Engineer
AKA: Phil Baltar
FRC #1351
Actually, I was going more along the lines of those people that perform an analysis on numbers in the bible and figure out the apocalypse.
As for the object, I meant what you would get if you flatten it. A cube would be 4 sides, a tetra would be 3... So a six-sided object would be some kind of extruded hexagon.
Version: 3.12
Unread 23-11-2005, 12:22
Best Available Data
FRC #1778 (Chill Out!)
With all the talk about batons and my research into last year that found many people hit the pyramid hint right on the head, could it be that we will simply see the return of PVC goals?
Last year we guessed pyramids and got pyramids missing the insides. This year we guess batons and get batons missing the insides, or pvc goals?
(Also ironically at the FLL tournament I attended last weekend there where baton twirlers selling Kettle Korn at 3 bucks for a bag about a foot tall and 4 inches in diameter raising money to go to DC...) Is this some subtle game hint?
Unread 23-11-2005, 12:59
artdutra04's Avatar
Maybe there will be hexagonal mobile goals again?
All the speculation so far is about batons being used for the actual playing field object. But what if they weren't? Following FIRST's ball-nonball game pattern of the recent years, we're due for a ball game. What if the batons really represent parts of a goal? What if there is going to be really short goals this year? What if these batons would be connected to make a ladder-like goal? Or maybe a fence/barrier?
Batons are usually easily moved about and manupulated by a cheerleader or such, so would this mean that there will be all mobile goals on the field? Would this represent some sort of dynamic field element(s)? Or would there be goals that don't belong to any specific alliance color by default, but to the alliance that puts more balls into it (similar to tetra goal ownership)? Would robots be able to easily manipulate the balls, and score them into goals without a human player? Would human players somehow alter goal ownership?
For a person to be able to manipulate a baton, it takes practice and skill. Would this mean that there will be a very difficult task to do, that only a small number of teams can accomplish? Will the balls be odd shaped, like footballs? Would this mean that an arm/elevator would be practically necessary for the game?
And the speculation continues...
Just to clarify, when I said a six-sided object was a cube in my previous post, I was thinking of six faces on a cube.
Art Dutra IV
世上无难事,只怕有心人.
Unread 24-11-2005, 01:37
KarenH's Avatar
KarenH KarenH is offline
Mrs. ChrisH
FRC #0330 (Beach 'Bots)
Team Role: Parent
KarenH has a reputation beyond reputeKarenH has a reputation beyond reputeKarenH has a reputation beyond reputeKarenH has a reputation beyond reputeKarenH has a reputation beyond reputeKarenH has a reputation beyond reputeKarenH has a reputation beyond reputeKarenH has a reputation beyond reputeKarenH has a reputation beyond reputeKarenH has a reputation beyond reputeKarenH has a reputation beyond repute
That must be it!! The Human Players will have to manipulate the batons--twirl them without dropping them--for the whole match! Double points for twirling two instead of just one. And think of the safety advantage--no more interacting with those dangerous robots!
Now all we have to do is figure out what on earth the robots are supposed to do.
Karen Husmann
Ex Robo-widow
Unread 24-11-2005, 13:25
FRC #0306 (CRT)
Maybe the human players have to beat each other with padded batons (like what the military uses for aggression training). The alliance with the most conscious member at the end gets to have their balls in goals count for double. I'm gonna go talk to the wrestling team...
-Sir Francis Bacon
-Albert Einstein
Unread 27-11-2005, 17:50
Ryan Foley Ryan Foley is offline
FRC #5687 (The Outliers)
Ryan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond repute
Oh good, Zone Zeal meets Dyabolical Dynamics meets FIRST Frenzy. Balance the 180lb Zone Zeal goals on the teeter totter bridge from 2001, THEN hang from a pull up bar that is attached to the teeter totter (directly above the bridge's balance point of course).
Oh, and dont forget to cap the goals with a tetra or doubler ball.
Ryan
FRC #5687: The Outliers [2015-?]
FRC #1995: Fatal Error [2007-2009]
FRC #350: Timberlane Robotics [2001-2004]
FRC/FLL volunteer since 2005
Unread 23-11-2005, 13:00
alphastryk's Avatar
alphastryk alphastryk is offline
1002 Student Leader
AKA: Brian Plattenburg
FRC #1002 (Circuitrunners)
alphastryk is an unknown quantity at this point
Send a message via AIM to alphastryk Send a message via MSN to alphastryk Send a message via Yahoo to alphastryk
maybe some sort of hexagonal tube (baton + hex)? im not sure how useful that wierd numbers theory is though...pvc tubes would make more sense as game objects...wouldnt they have infinite sides because they are circles? hmm...
Team 1002 - Wheeler High Circuit Runners
Marietta Georgia - www.circuitrunners.com
-2006 Chairman's Award Winner - Peachtree Reigonal
-2005 Chairman's Award Winner - Peachtree Regional
-2004 Chairman's Award Winner - Peachtree Regional
-2004 Chairman's Award Honorable Mention - Atlanta Championship Competition
-2004 Competition Winner - Peachtree Regional - Undefeated in 6 straight playoff matches
-2004 DaimlerChrysler Team Spirit Award - Peachtree Regional
-2004 Kleiner, Perkins, Caufield & Byers Entrepreneurship Award - VCU Regional
-2004 Website Excellence Award
-2003 Rookie All Star - Peachtree Regional
-2003 Johnson & Johnson Sportsmanship Award - Peachtreee Regional-
[Official 2006 Game Design] OK, so YOU design the 2006 game... dlavery FRC Game Design 29 08-01-2006 00:21
2006 Game Thread miketwalker FRC Game Design 61 30-03-2005 19:15
2004 Season for Fantasy Football, FIRST Robotics league Alex Cormier Chit-Chat 155 29-12-2004 13:12
Thank you for this game! DougHogg Thanks and/or Congrats 10 10-03-2004 22:11
i didnt like this years game....please read archiver 2001 19 24-06-2002 03:23
