Go to Post I think Baker has lost it. - Andy Baker [more]
Go Back   Chief Delphi > Old Forum Archives > 1999
Unread 23-06-2002, 21:57
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
I Need Help with downloading Basic Stamp Program
Posted by Joseph, Other on team #252, Bay Bombers, from Broadway High School and NASA.
Posted on 3/4/99 10:06 AM MST
I have modified the Basic Stamp program that comes with
the control box. When I use the command to send the
file alt R I keep getting the message.
"Hardware not found"
I have tried to down load the
program with two different PC's using the COM port.
Initially I used the standard file transfer cable
provided with the PC's. I also built a cable based on
spec's provided on the First SW floopy that came with
the kit. I am using Stamp2. I have gone through and
checked the device drivers and COM systems and am fairly
sure that both PC's are operating correctly. I have used
the COM port on one the the pc's before with no problem.
I really need help. Please alpha page me if you have
any ideas.
Mark Joseph
800-774-9737
#0047 (ChiefDelphi)
Re: I Need Help with downloading Basic Stamp Program
Posted by Jeremy M. Husic, Engineer on team #47, Chief Delphi, from Ponitac Central High School and Delphi Automotive Systems.
Posted on 3/4/99 11:59 AM MST
In Reply to: I Need Help with downloading Basic Stamp Program posted by Joseph on 3/4/99 10:06 AM MST:
: I have modified the Basic Stamp program that comes with
: the control box. When I use the command to send the
: file alt R I keep getting the message.
: "Hardware not found"
: I have tried to down load the
: program with two different PC's using the COM port.
: Initially I used the standard file transfer cable
: provided with the PC's. I also built a cable based on
: spec's provided on the First SW floopy that came with
: the kit. I am using Stamp2. I have gone through and
: checked the device drivers and COM systems and am fairly
: sure that both PC's are operating correctly. I have used
: the COM port on one the the pc's before with no problem.
: I really need help. Please alpha page me if you have
: any ideas.
: Mark Joseph
: 800-774-9737
I can think of a few things you might try.
1. You may have the reciever box still in the default program mode. You
need to switch to User Program mode. This is done by flipping one of
the switches on the 4 switch DIP, next to the programming port. As
per the FIRST manual, you need to flip switch 2 down and switches
1,3,4 up (see page 26 of the "The Robot" section).
2. Check that +5V is getting to the Stamp2. You can check this by
plugging in logic power, then check that all the amber lights are on.
If not then you might have a blown +5V fuse.
3. Use the 9pin cable provided in the First kit.
If you need any help page me at 810.704.8716
PS: The pager number in your message goes to a business that has never
heard of you.
#0047 (ChiefDelphi)
Posted by Jerry Eckert, Engineer on team #140 from Tyngsboro, MA High School and New England Prototype/Brooks Automation.
Posted on 3/4/99 2:01 PM MST
In Reply to: Re: I Need Help with downloading Basic Stamp Program posted by Jeremy M. Husic on 3/4/99 11:59 AM MST:
: : I have modified the Basic Stamp program that comes with
: : the control box. When I use the command to send the
: : file alt R I keep getting the message.
: : "Hardware not found"
Another thing to check is that software is accessing the same serial port you have the cable connected to.
[IMG] code is Off
Impending BASIC Stamp Editor Beta 2 release Greg Ross Programming 9 19-09-2003 06:05
Auxilliary Basic Stamp Chip Kai Zhao Technical Discussion 9 07-01-2003 21:21
no basic stamp found! DLyons Programming 7 23-12-2002 22:17
Is anyone using the BASIC Stamp Preprocessor? Greg Ross Programming 4 12-02-2002 12:24
Question about Basic Stamp miketwalker Programming 3 14-01-2002 13:10
