Go to Post That's wicked sweet (and I'm not even from New England). - Travis Hoffman [more]
Go Back   Chief Delphi > Old Forum Archives > 2000
Unread 23-06-2002, 22:29
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
Re: Bad, bad, bad!!! - I agree
Posted by Raul.
Engineer on team #111, Wildstang, from Rolling Meadows & Wheeling HS and Motorola.
Posted on 1/12/2000 7:03 AM MST
In Reply to: Bad, bad, bad!!! posted by Daniel on 1/12/2000 12:12 AM MST:
I think that having the rule that all replacement parts have to be fabbed before shipment is tougher on the low-budget teams.
Those with bigger budgets will likely have multiples made of many things because it is cheaper to do it that way. It cost less to make 2 of something once then to make one and then have to set up again to make another one.
FIRST should allow identical replacement parts to be made anytime. They should, as the update says, allow improvements to be fabbed from the time you check in to the time you ship at the competition.
Raul
[IMG] code is Off
Battle-Bots vs. FIRST: good or bad? Kojib Televised Robotics 11 01-03-2004 02:01
college counseling decides to help us... good or bad? AlbertW General Forum 4 16-05-2003 15:14
RCU has bad Analog ports - what now? Icebreakers Programming 13 26-03-2003 07:27
Chiaphua Motors: Good or Bad to 2002 Kit Of Parts? D.J. Fluck Motors 25 05-07-2002 16:40
Good or bad: back wheels coming off the ground Gui Cavalcanti Technical Discussion 2 17-03-2002 22:09
